Localized language files for 7.4.9c ?
w.leroy
Hey there,
We recently upgraded our SPA504G and SPA525G2 to the latest revision (7.4.9c), without having the corresponding language files ( we only have spa50x_30x_XX_v745.xml and spa525_XX_v745.xml files )  : it appears some of the messages and softkeys labels are still displayed in English whatever language the enduser chose.  I guess some new items appeared after the 7.4.5 version which don't exist in the 7.4.5 language files, but how can we obtain the latest language files ?
Best regards,
Willy
Willy,
I've placed the 7.4.9 localization dictionaries here:
https://supportforums.cisco.com/docs/DOC-19878
Patrick
Patrick Born
Hi Willy,
The 7.4.8 dictionaries will be closer to 7.4.9 than what you're current using. They are available from here:
https://supportforums.cisco.com/docs/DOC-9923
I'll get back to you with when 7.4.9 dictionaries will be published.
Patrick
   Patrick Born | Technical Marketing Engineer (TME) – SPA SIP Endpoints
                    Use this reference document to locate SPA phone resources
Willy,
Patrick
Wow, now that was fast !
I was installing the 7.4.8 files and realized you posted the 7.4.9 dictionaries in the meantime : )
Thanks, this is much appreciated !
Best regards,
