MWI Stopped Working
jcabral
MWI Stopped working recently on a UC520. I ran a MWI refresh all from cli
and GUI and still not working. I checked the SIP gateway which is set to
10.1.1.1 and I also checked the ephone-dn for MWI 800.... and 801.... both
have the correct four dots as we are using 4 digit extensions. How else
should I troubleshoot this issue.
Thanks.
jcabral
I beleive I found the issue but not sure how to resolve it. It seems that extension is stuck off hook:
50/0/128 1   IDLE         NONE         None       -  S_WAIT_STATS          EFXS_WAIT_OFFHOOK
When I try to delete the ephone-dn to recreate I cannot since is in use. How do I fix this issue ?
MWI Issue - Resolved
To get the state out of the off hook mode I change the mwi on that extension to off rather than on. Then I used the refresh mwi all command and that brougt the state back to normal. Then turned back the mwi. That seemed to work. Just to be sure I was able to delete the ephone-dn and recreate. Should be allset need to wait to confirm with customer.
Thanks.
