No phone will register with UC540 anymore
Todd Lewis
We have a UC540 in production.  It has been working perfectly for the last couple of years.  We added 3 phones last week that booted normally and we were able to make calls from.  Over the weekend all phones lost registration with the UC and none will re-register.  The phones are picking up DHCP from the UC itself.  I can ping the phones and I can access its web GUI.  We have 15 phones and 30 licenses right now.  The UC is running firmware version 8.6.0.  Any help is greatly appreciated.
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC-LPCS
boot-start-marker
boot-end-marker
enable secret 4 I9wZwinuoKwLTyNG893fGheGzOe2PnhZARHRO/9IGe2k
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-2771775400
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-2771775400
 revocation-check none
 rsakeypair TP-self-signed-2771775400
crypto pki certificate chain TP-self-signed-2771775400
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32373731 37373534 3030301E 170D3135 30373238 31353032
  31305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 37373137
  37353430 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A212 E316D71D CC5CD56B 5734899B D794E400 87EE27FF 2F61C9C7 28E8EFEA
  59F50A35 F651A3EC FA8D070B A9062EEF 1BD04E76 AE562957 92D44673 A6A4AE1A
  1BDFDD62 40D8E496 AD1CE686 9991F807 B8DB85FE F60BAE0F A41A2750 E8D1A6AB
  6900060C 5CC55D8E 33D4DC68 F24ECEAB BE6CDD42 84321FDB DB125E7B 05804015
  82190203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14B85BB4 C3FC45D6 E2AB8DA8 75CF88DB 76DA4FCC EB301D06
  03551D0E 04160414 B85BB4C3 FC45D6E2 AB8DA875 CF88DB76 DA4FCCEB 300D0609
  2A864886 F70D0101 05050003 81810069 71AD6F3A 251AEA97 D0D18923 41B957AD
  3F27EF7F C55032FD 515CC7F3 81931AE0 CD26FB5F FA727779 D2C2B649 E3340409
  B61F7D7C 6089B478 09C3C50A 136ED203 57691AD9 FCDC2E61 F420E7FE 6DABD385
  E934929E A655D2DB E024A302 7F91E8D5 7CF55379 255EB4F7 A1EA05DA 12DD04B7
  0978FDD0 2DD8A6D8 78CD1AC5 293AD6
        quit
dot11 syslog
dot11 ssid cisco-data
 vlan 1
 authentication open
dot11 ssid cisco-voice
 vlan 100
 authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
 network 10.1.1.0 255.255.255.0
 default-router 10.1.1.1
 option 150 ip 10.1.1.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
trunk group ALL_FXO
 max-retry 5
 voice-class cause-code 1
 hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service h450.2
 no supplementary-service h450.3
 supplementary-service h450.12
 sip
  registrar server expires max 36000 min 600
  no update-callerid
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class cause-code 1
 no-circuit
voice register global
 mode cme
 source-address 10.1.1.1 port 5060
 max-dn 1
 max-pool 1
 load 9971 sip9971.9-2-2
 load 9951 sip9951.9-2-2
 load 8961 sip8961.9-2-2
 timezone 8
 create profile sync 0005105201758921
voice register dn  1
 number 444
 no-reg
voice register pool  1
 id mac 0020.F702.E3A4
 number 1 dn 1
 dtmf-relay rtp-nte
 username 444 password ext444
 codec g711ulaw
 no vad
voice translation-rule 1000
 rule 1 /.*/ //
voice translation-rule 1112
 rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
 rule 1 /^6/ //
voice translation-rule 2222
 rule 1 /^91900......./ //
 rule 2 /^91976......./ //
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
 translate calling 1111
voice translation-profile CallBlocking
 translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
 translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
 translate redirect-called 2002
voice translation-profile nondialable
 translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC540W-FXO-K9 sn FGL173320KC
archive
 log config
  logging enable
  logging size 600
  hidekeys
username administrator privilege 15 secret 4 I9wZwinuG872fFGsilwqeGzOe2PnhZARHRO/9IH73l
ip tftp source-interface Loopback0
bridge irb
interface Loopback0
 description $FW_INSIDE$
 ip address 10.1.10.2 255.255.255.252
 ip nat inside
 ip virtual-reassembly in
interface FastEthernet0/0
 description $FW_OUTSIDE$
 ip address dhcp client-id FastEthernet0/0
 ip access-group 104 in
 ip nat outside
 ip inspect SDM_LOW out
 load-interval 30
 shutdown
 duplex auto
 speed auto
interface Integrated-Service-Engine0/0
 description cue is initialized with default IMAP group
 ip unnumbered Loopback0
 ip nat inside
 shutdown
 service-module ip address 10.1.10.1 255.255.255.252
 service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
 switchport voice vlan 100
 no ip address
 macro description cisco-phone
 spanning-tree portfast
interface FastEthernet0/1/1
 no ip address
interface FastEthernet0/1/2
 no ip address
interface FastEthernet0/1/3
 no ip address
interface FastEthernet0/1/4
 no ip address
interface FastEthernet0/1/5
 no ip address
interface FastEthernet0/1/6
 no ip address
interface FastEthernet0/1/7
 no ip address
interface FastEthernet0/1/8
 switchport mode trunk
 no ip address
 macro description cisco-switch
interface Dot11Radio0/5/0
 no ip address
 shutdown
 ssid cisco-data
 ssid cisco-voice
 speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
 station-role root
 antenna receive right
 antenna transmit right
interface Dot11Radio0/5/0.1
 encapsulation dot1Q 1 native
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
 encapsulation dot1Q 100
 bridge-group 100
 bridge-group 100 subscriber-loop-control
 bridge-group 100 spanning-disabled
 bridge-group 100 block-unknown-source
 no bridge-group 100 source-learning
 no bridge-group 100 unicast-flooding
interface Vlan1
 no ip address
 bridge-group 1
interface Vlan100
 no ip address
 bridge-group 100
interface BVI1
 ip address 10.150.10.8 255.255.254.0
 ip nat inside
 h323-gateway voip bind srcaddr 10.150.10.8
interface BVI100
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
ip default-gateway 10.150.10.5
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 10.150.10.5
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.1.1.0 0.0.0.255
access-list 1 permit 10.150.10.0 0.0.1.255
access-list 1 permit 10.1.10.0 0.0.0.3
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip 10.150.10.0 0.0.1.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration##NO_ACES_5##
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration##NO_ACES_7##
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 deny   ip 10.1.10.0 0.0.0.3 any
access-list 103 deny   ip 10.150.10.0 0.0.1.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration##NO_ACES_13##
access-list 104 remark SDM_ACL Category=1
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 deny   ip 10.150.10.0 0.0.1.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any log
snmp-server community public RO
radius-server attribute 31 send nas-port-detail
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
 station-id number 401
 caller-id enable
voice-port 0/0/1
 station-id number 402
 caller-id enable
voice-port 0/0/2
 station-id number 403
 caller-id enable
voice-port 0/0/3
 station-id number 404
 caller-id enable
voice-port 0/1/0
 trunk-group ALL_FXO 64
 connection plar opx 130
 description Configured by CCA 4 FXO-0/1/0-OP
 caller-id enable
voice-port 0/1/1
 description Configured by CCA 4 FXO-0/1/1-OP
 caller-id enable
voice-port 0/1/2
 description Configured by CCA 4 FXO-0/1/2-OP
 caller-id enable
voice-port 0/1/3
 description Configured by CCA 4 FXO-0/1/3-OP
 caller-id enable
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/4/0
 auto-cut-through
 signal immediate
 input gain auto-control -15
 description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
 associate ccm 1 priority 1
dial-peer cor custom
 name internal
 name local
 name local-plus
 name international
 name national
 name national-plus
 name emergency
 name toll-free
dial-peer cor list call-internal
 member internal
dial-peer cor list call-local
 member local
dial-peer cor list call-local-plus
 member local-plus
dial-peer cor list call-national
 member national
dial-peer cor list call-national-plus
 member national-plus
dial-peer cor list call-international
 member international
dial-peer cor list call-emergency
 member emergency
dial-peer cor list call-toll-free
 member toll-free
dial-peer cor list user-internal
 member internal
 member emergency
dial-peer cor list user-local
 member internal
 member local
 member emergency
 member toll-free
dial-peer cor list user-local-plus
 member internal
 member local
 member local-plus
 member emergency
 member toll-free
dial-peer cor list user-national
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer cor list user-national-plus
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer cor list user-international
 member internal
 member local
 member local-plus
 member national
 member emergency
 member toll-free
dial-peer voice 1 pots
 destination-pattern 401
 port 0/0/0
 no sip-register
dial-peer voice 2 pots
 destination-pattern 402
 port 0/0/1
 no sip-register
dial-peer voice 3 pots
 destination-pattern 403
 port 0/0/2
 no sip-register
dial-peer voice 4 pots
 destination-pattern 404
 port 0/0/3
 no sip-register
dial-peer voice 5 pots
 description ** MOH Port **
 destination-pattern ABC
 port 0/4/0
 no sip-register
dial-peer voice 6 pots
 description tcatch all dial peer for BRI/PRIv
 translation-profile incoming nondialable
 incoming called-number .%
 direct-inward-dial
dial-peer voice 50 pots
 description ** incoming dial peer **
 incoming called-number ^AAAA$
 port 0/1/0
dial-peer voice 51 pots
 port 0/1/1
dial-peer voice 52 pots
 port 0/1/2
dial-peer voice 53 pots
 port 0/1/3
dial-peer voice 54 pots
 description ** FXO pots dial-peer **
 destination-pattern A0
 port 0/1/0
 no sip-register
dial-peer voice 55 pots
 destination-pattern A1
 port 0/1/1
 no sip-register
dial-peer voice 56 pots
 destination-pattern A2
 port 0/1/2
 no sip-register
dial-peer voice 57 pots
 destination-pattern A3
 port 0/1/3
 no sip-register
dial-peer voice 2000 voip
 description ** cue voicemail pilot number **
 translation-profile outgoing XFER_TO_VM_PROFILE
 destination-pattern 399
 b2bua
 session protocol sipv2
 session target ipv4:10.1.10.1
 voice-class sip outbound-proxy ipv4:10.1.10.1
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2001 voip
 description ** cue auto attendant number **
 translation-profile outgoing PSTN_CallForwarding
 destination-pattern 398
 b2bua
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 2012 voip
 description ** cue prompt manager number **
 destination-pattern 397
 b2bua
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 58 pots
 trunkgroup ALL_FXO
 corlist outgoing call-emergency
 description **CCA*North American-7-Digit*Emergency**
 translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
 preference 5
 destination-pattern 9911
 forward-digits all
 no sip-register
dial-peer voice 59 pots
 trunkgroup ALL_FXO
 preference 5
 destination-pattern 911
 forward-digits all
 no sip-register
dial-peer voice 60 pots
 trunkgroup ALL_FXO
 corlist outgoing call-local
 description **CCA*North American-7-Digit*7-Digit Local**
 preference 5
 destination-pattern 9[2-9]......
 forward-digits all
 no sip-register
dial-peer voice 61 pots
 trunkgroup ALL_FXO
 description **CCA*North American-7-Digit*Service Numbers**
 preference 5
 destination-pattern 9[2-9]11
 forward-digits all
 no sip-register
dial-peer voice 62 pots
 trunkgroup ALL_FXO
 corlist outgoing call-national
 description **CCA*North American-7-Digit*Long Distance**
 preference 5
 destination-pattern 91[2-9]..[2-9]......
 forward-digits all
 no sip-register
dial-peer voice 63 pots
 trunkgroup ALL_FXO
 corlist outgoing call-international
 description **CCA*North American-7-Digit*International**
 preference 5
 destination-pattern 9011T
 forward-digits all
 no sip-register
dial-peer voice 64 pots
 trunkgroup ALL_FXO
 corlist outgoing call-toll-free
 description **CCA*North American-7-Digit*Toll-Free**
 preference 5
 destination-pattern 91800.......
 forward-digits all
 no sip-register
dial-peer voice 65 pots
 trunkgroup ALL_FXO
 preference 5
 destination-pattern 91888.......
 forward-digits all
 no sip-register
dial-peer voice 66 pots
 trunkgroup ALL_FXO
 preference 5
 destination-pattern 91877.......
 forward-digits all
 no sip-register
dial-peer voice 67 pots
 trunkgroup ALL_FXO
 preference 5
 destination-pattern 91866.......
 forward-digits all
 no sip-register
dial-peer voice 68 pots
 trunkgroup ALL_FXO
 preference 5
 destination-pattern 91855.......
 forward-digits all
 no sip-register
dial-peer voice 100 pots
 port 0/2/0
dial-peer voice 101 pots
 port 0/2/1
dial-peer voice 102 pots
 port 0/2/2
dial-peer voice 103 pots
 port 0/2/3
no dial-peer outbound status-check pots
telephony-service
 video
 fxo hook-flash
 max-ephones 40
 max-dn 300
 ip source-address 10.1.1.1 port 2000
 auto assign 1 to 1 type bri
 calling-number initiator
 service phone videoCapability 1
 service phone ehookenable 1
 service dnis overlay
 service dnis dir-lookup
 service dss
 timeouts interdigit 5
 system message Leadership Prep
 url services http://10.1.10.1/voiceview/common/login.do
 url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
 load 7914 S00105000400
 load 7915-12 B015-1-0-4
 load 7915-24 B015-1-0-4
 load 7916-12 B016-1-0-4
 load 7916-24 B016-1-0-4
 load 7906 SCCP11.9-2-1S
 load 7911 SCCP11.9-2-1S
 load 7921 CP7921G-1.4.1SR1
 load 7925 CP7925G-1.4.1SR1
 load 7931 SCCP31.9-1-1SR1S
 load 7936 cmterm_7936.3-3-21-0
 load 7937 apps37sccp.1-4-4-0
 load 7960-7940 P00308010200
 load 7941 SCCP41.9-1-1SR1S
 load 7941GE SCCP41.9-1-1SR1S
 load 7942 SCCP42.9-1-1SR1S
 load 7945 SCCP45.9-1-1SR1S
 load 7961 SCCP41.9-1-1SR1S
 load 7961GE SCCP41.9-1-1SR1S
 load 7962 SCCP42.9-1-1SR1S
 load 7965 SCCP45.9-1-1SR1S
 load 7970 SCCP70.9-1-1SR1S
 load 7971 SCCP70.9-1-1SR1S
 load 7975 SCCP75.9-1-1SR1S
 load 521G-524G cp524g-8-1-17
 load 525G spa525g-7-4-9c
 load 501G spa50x-30x-7-4-9c
 load 502G spa50x-30x-7-4-9c
 load 504G spa50x-30x-7-4-9c
 load 508G spa50x-30x-7-4-9c
 load 509G spa50x-30x-7-4-9c
 load 525G2 spa525g-7-4-9c
 load 301 spa50x-30x-7-4-9c
 load 303 spa50x-30x-7-4-9c
 load 6921 SCCP69xx.9-1-1-2-sr
 load 6941 SCCP69xx.9-1-1-2-sr
 load 6961 SCCP69xx.9-1-1-2-sr
 load 6901 SCCP6901.9-1-1-0
 load 6911 SCCP6911.9-1-1-0
 time-zone 8
 keepalive 30 auxiliary 4
 voicemail 399
 max-conferences 8 gain -6
 call-forward pattern .T
 call-forward system redirecting-expanded
 moh flash:/media/music-on-hold.au
 multicast moh 239.10.16.16 port 2000
 web admin system name cisco secret 5 $1$d6CQ$Sx130JMPzoVBImM/nmpBy1
 dn-webedit
 time-webedit
 transfer-system full-consult dss
 transfer-pattern 9.T
 transfer-pattern .T
 transfer-pattern 6... blind
 secondary-dialtone 9
 night-service day Sun 17:00 09:00
 night-service day Mon 17:00 09:00
 night-service day Tue 17:00 09:00
 night-service day Wed 17:00 09:00
 night-service day Thu 17:00 09:00
 night-service day Fri 17:00 09:00
 night-service day Sat 17:00 09:00
 fac standard
ephone-template  15
 url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
 softkeys remote-in-use  Newcall
 softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
 softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
 softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
 button-layout 7931 2
ephone-template  16
ephone-template  17
 softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  1
 number 101 no-reg primary
 description IP-Paging1
 name Office
 paging ip 239.1.1.1 port 2000
ephone-dn  2
 number 102 no-reg primary
 description IP-Paging2
 name Classrooms
 paging ip 239.1.1.2 port 2000
ephone-dn  3
 number 103 no-reg primary
 description IP-Paging3
 name All
 paging ip 239.1.1.3 port 2000
 paging group 1,2
ephone-dn  9
 number BCD no-reg primary
 description MoH
 moh out-call ABC
ephone-dn  284  dual-line
 number 230 no-reg primary
 label 230
 description Cafeteria
 name Cafeteria Room
 call-forward busy 399
 call-forward noan 399 timeout 20
ephone-dn  285  dual-line
 number 220 no-reg primary
 label 220
 description Fletcher/Smith
 name Classroom OneFourteen
ephone-dn  286  dual-line
 number 210 no-reg primary
 label 210
 description Mr.Brownlee
 name Classroom OneSixteen
ephone-dn  287  dual-line
 number 140 no-reg primary
 label Work Room
 description Work Room
 name Teacher WorkRoom
ephone-dn  288  dual-line
 number 200 no-reg primary
 label 200
 description Classroom Six
 name Classroom Six
ephone-dn  289  dual-line
 number 190 no-reg primary
 label 190
 description Classroom Five
 name Classroom Five
ephone-dn  290  dual-line
 number 180 no-reg primary
 label 180
 description Classroom Four
 name Classroom Four
ephone-dn  291  dual-line
 number 170 no-reg primary
 label 170
 description Classroom Three
 name Classroom Three
ephone-dn  292  dual-line
 number 160 no-reg primary
 label 160
 description Classroom Two
 name Classroom Two
ephone-dn  293  dual-line
 number 150 no-reg primary
 label 150
 description Classroom One
 name Classroom One
ephone-dn  294  dual-line
 number 130 no-reg primary
 label 130
 description Kanesha Johnson
 name Kanesha Johnson
ephone-dn  295  dual-line
 number 120 no-reg primary
 label 120
 description Tammy Butler
 name Tammy Butler
ephone-dn  296  dual-line
 number 110 no-reg primary
 label 110
 description Valissia Allen
 name Valissia Allen
ephone-dn  297  dual-line
 number 100 no-reg primary
 label 100
 description Jeffrey VealeJr
 name Jeffrey VealeJr
ephone-dn  298
 number 6... no-reg primary
 description ***CCA XFER TO VM EXTENSION***
 call-forward all 399
ephone-dn  299
 number A801... no-reg primary
 mwi off
ephone-dn  300
 number A800... no-reg primary
 mwi on
ephone  1
 device-security-mode none
 mac-address 580A.2086.9913
 ephone-template 16
 max-calls-per-button 2
 username "KJohnson" password 123456
 paging-dn 1
 type 509G
 button  1:294
ephone  2
 mac-address 381C.1AB7.FB17
 ephone-template 16
 username "JVealeJr" password 123456
 paging-dn 1
 type 504G
 button  1:297
ephone  3
 mac-address 381C.1AB7.FB00
 ephone-template 16
 username "VAllen" password 123456
 paging-dn 1
 type 504G
 button  1:296
ephone  4
 mac-address 381C.1AB7.FB1E
 ephone-template 16
 username "TButler" password 123456
 paging-dn 1
 type 504G
 button  1:295
ephone  5
 mac-address 381C.1AB7.FB48
 ephone-template 16
 username "CSix" password 123456
 type 504G
 button  1:288
ephone  6
 mac-address 381C.1AB7.FB16
 ephone-template 16
 username "COne" password 123456
 paging-dn 2
 type 504G
 button  1:293
ephone  7
 mac-address 381C.1AB7.FB2A
 ephone-template 16
 username "CTwo" password 123456
 paging-dn 2
 type 504G
 button  1:292
ephone  8
 mac-address 381C.1AB7.FB3E
 ephone-template 16
 username "CThree" password 123456
 paging-dn 2
 type 504G
 button  1:291
ephone  9
 mac-address 381C.1AB7.FB33
 ephone-template 16
 username "CFour" password 123456
 paging-dn 2
 type 504G
 button  1:290
ephone  10
 mac-address 381C.1AB7.FB01
 ephone-template 16
 username "CFive" password 123456
 type 504G
 button  1:289
ephone  11
 mac-address 381C.1AB7.FB34
 ephone-template 16
 username "WorkRoom" password 123456
 paging-dn 1
 type 504G
 button  1:287
ephone  12
 mac-address 2C86.D210.36FE
 ephone-template 16
 username "Room116" password 123456
 type 504G
 button  1:286
ephone  13
 mac-address 2C86.D210.36F1
 ephone-template 16
 username "Cafeteria" password 123456
 type 504G
 button  1:284
ephone  14
 mac-address 2C86.D210.36D0
 ephone-template 16
 username "Room114" password 123456
 type 504G
 button  1:285
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (3). Tue Jul 28 10:20:29 CDT 2015^^C
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
line vty 0 4
 exec-timeout 30 0
 transport input all
line vty 5 100
 transport input all
ntp master
end
0 Replies 0
