Norwegian characters in inputs on SPA504G
sengebretsen
When working with CiscoIPPhone XML Objects on SPA504G, I cannot figure out how to enable Norwegian characters (æ, ø and å) in the CiscoIPPhoneInput box – or to be more specific, when hitting the 2-button, I can chose between [a, b, c, 2, A, B, C] when I want to be able to chose from [a, b, c, æ, 2, A, B, C, Æ].
The characters are displayed fine when just printed out as text (ie. in the header/title of the same window).
I have selected UTF-8 as character encoding on the phone configuration, and I've tried both to print out accept-charset and content-type where I specifie UTF-8 as charset.
On SPA525G, it works like a charm. All Norwegian characters are available.
Is this solvable? Or is it a limit on the 504 model?
Thanks in advance.
Eivind Jonassen
Level 4
Level 4
We are also experiencing another issue. Translation on the softkeys answer, ignore and endcall are not possible to change from english to norwegian. This has to be a bug?!
Also, the phones are running SIP in both of the issues described here.
Eivind
