One PC with very slow Internet connection on other side of SPA303 phone
BikeFitIT
We have 4 month old SPA303 phones [hw version 1.0.0(0001)] running the latest firmware [7.4.7].   Each of the 4 phones each have a PC connected via a Cat5 cable to the "PC" port on the underside.  Unfortunately, the Internet connection on one PC (Lenovo X201, Windows 7 x64 w/ SP3) is so slow it is unusuable.  Accessing most web pages eventually results in them timing out.  Connecting the PC using the Cat5 that was previously connected to the phone's "SW" port (in other words, bypassing the phone entirely) results in a positive expected behavior--a fast Internet connection with web pages that load.  Connecting another Win7 x64 PC through the phone also results in a usable Internet connection.  Net net: only one PC is having problems through the Internet connection.  Does anyone have any diagnostics tips for finding the root cause of this issue?
Here is the info from the phone with issues:
Connection Type:    DHCPCurrent IP:    192.168.0.83
Host Name:    102Domain:
Current Netmask:    255.255.255.0Current Gateway:    192.168.0.1
Primary DNS:    4.2.2.2
Secondary DNS:    208.67.222.222
Product Information
Product Name:    SPA303Serial Number:    DeletedforPrivacy
Software Version:7.4.7Hardware Version:    1.0.0(0001)
MAC Address:    DeletedforPrivacyClient Certificate:    Installed
Customization:    OpenLicenses:    None
Phone Status
Current Time:    3/7/2011 10:49:15Elapsed Time:    00:32:36
Broadcast Pkts Sent:5Broadcast Bytes Sent:812
Broadcast Pkts Recv:    1891Broadcast Bytes Recv:    189461
Broadcast Pkts Dropped:    0Broadcast Bytes Dropped:0
RTP Packets Sent:    0RTP Bytes Sent:    0
RTP Packets Recv:    0RTP Bytes Recv:    0
SIP Messages Sent:    171SIP Bytes Sent:    138419
SIP Messages Recv:    170SIP Bytes Recv:    87043
External IP:    DeletedforPrivacyOperational VLAN ID:    0
SW Port:    100M Full DuplexPC Port:    Link Down
Ext 1 Status
Registration State:    RegisteredLast Registration At:    3/7/2011 10:49:14
Next Registration In:    22 sMessage Waiting:    No
Mapped SIP Port:    5060
Here is the PC's network information (it has an Intel(R) 82577LM Gigabit NIC) :
Name [00000000] WAN Miniport (SSTP)
Adapter Type Not Available
Product Type WAN Miniport (SSTP)
Installed Yes
PNP Device ID ROOT\MS_SSTPMINIPORT\0000
Last Reset 3/3/2011 10:32 PM
Index 0
Service Name RasSstp
IP Address Not Available
IP Subnet Not Available
Default IP Gateway Not Available
DHCP Enabled No
DHCP Server Not Available
DHCP Lease Expires Not Available
DHCP Lease Obtained Not Available
MAC Address Not Available
Driver c:\windows\system32\drivers\rassstp.sys (6.1.7600.16385, 82.00 KB (83,968 bytes), 7/13/2009 5:10 PM)
Name [00000001] WAN Miniport (IKEv2)
Product Type WAN Miniport (IKEv2)
Installed Yes
PNP Device ID ROOT\MS_AGILEVPNMINIPORT\0000
Index 1
Service Name RasAgileVpn
DHCP Enabled No
Driver c:\windows\system32\drivers\agilevpn.sys (6.1.7600.16385, 59.00 KB (60,416 bytes), 7/13/2009 5:10 PM)
Name [00000002] WAN Miniport (L2TP)
Product Type WAN Miniport (L2TP)
Installed Yes
PNP Device ID ROOT\MS_L2TPMINIPORT\0000
Index 2
Service Name Rasl2tp
DHCP Enabled No
Driver c:\windows\system32\drivers\rasl2tp.sys (6.1.7600.16385, 127.00 KB (130,048 bytes), 7/13/2009 5:10 PM)
Name [00000003] WAN Miniport (PPTP)
Product Type WAN Miniport (PPTP)
Installed Yes
PNP Device ID ROOT\MS_PPTPMINIPORT\0000
Index 3
Service Name PptpMiniport
DHCP Enabled No
Driver c:\windows\system32\drivers\raspptp.sys (6.1.7600.16385, 109.00 KB (111,616 bytes), 7/13/2009 5:10 PM)
Name [00000004] WAN Miniport (PPPOE)
Product Type WAN Miniport (PPPOE)
Installed Yes
PNP Device ID ROOT\MS_PPPOEMINIPORT\0000
Index 4
Service Name RasPppoe
DHCP Enabled No
Driver c:\windows\system32\drivers\raspppoe.sys (6.1.7600.16385, 90.50 KB (92,672 bytes), 7/13/2009 5:10 PM)
Name [00000005] WAN Miniport (IPv6)
Product Type WAN Miniport (IPv6)
Installed Yes
PNP Device ID ROOT\MS_NDISWANIPV6\0000
Index 5
Service Name NdisWan
DHCP Enabled No
Driver c:\windows\system32\drivers\ndiswan.sys (6.1.7600.16385, 160.50 KB (164,352 bytes), 7/13/2009 5:10 PM)
Name [00000006] WAN Miniport (Network Monitor)
Product Type WAN Miniport (Network Monitor)
Installed Yes
PNP Device ID ROOT\MS_NDISWANBH\0000
Index 6
DHCP Enabled No
Name [00000007] Microsoft ISATAP Adapter
Adapter Type Tunnel
Product Type Microsoft ISATAP Adapter
Installed Yes
PNP Device ID ROOT\*ISATAP\0000
Index 7
Service Name tunnel
DHCP Enabled No
Driver c:\windows\system32\drivers\tunnel.sys (6.1.7600.16385, 122.50 KB (125,440 bytes), 7/13/2009 5:09 PM)
Name [00000008] WAN Miniport (IP)
Product Type WAN Miniport (IP)
Installed Yes
PNP Device ID ROOT\MS_NDISWANIP\0000
Index 8
DHCP Enabled No
Name [00000009] Bluetooth Device (Personal Area Network)
Product Type Bluetooth Device (Personal Area Network)
Installed Yes
PNP Device ID Not Available
Index 9
Service Name BthPan
DHCP Enabled Yes
Name [00000010] RAS Async Adapter
Adapter Type Wide Area Network (WAN)
Product Type RAS Async Adapter
Installed Yes
PNP Device ID SW\{EEAB7790-C514-11D1-B42B-00805FC1270E}\ASYNCMAC
Index 10
Service Name AsyncMac
DHCP Enabled No
MAC Address 20:41:53:59:4E:FF
Driver c:\windows\system32\drivers\asyncmac.sys (6.1.7600.16385, 22.50 KB (23,040 bytes), 7/13/2009 5:10 PM)
Name [00000012] Intel(R) 82577LM Gigabit Network Connection
Adapter Type Ethernet 802.3
Product Type Intel(R) 82577LM Gigabit Network Connection
Installed Yes
PNP Device ID PCI\VEN_8086&DEV_10EA&SUBSYS_215317AA&REV_06\3&E89B380&0&C8
Index 12
Service Name e1kexpress
DHCP Enabled Yes
MAC Address RemovedforPrivacy
Memory Address 0xF2500000-0xF251FFFF
Memory Address 0xF2525000-0xF2525FFF
IRQ Channel IRQ 4294967293
Driver c:\windows\system32\drivers\e1k62x64.sys (11.5.10.1030, 288.67 KB (295,600 bytes), 12/12/2010 2:54 PM)
Name [00000013] Microsoft ISATAP Adapter
Adapter Type Tunnel
Installed Yes
PNP Device ID ROOT\*ISATAP\0001
Index 13
Service Name tunnel
DHCP Enabled No
Name [00000014] Microsoft 6to4 Adapter
Adapter Type Tunnel
Product Type Microsoft 6to4 Adapter
Installed Yes
PNP Device ID ROOT\*6TO4MP\0000
Index 14
Service Name tunnel
DHCP Enabled No
Name [00000015] Intel(R) Centrino(R) Advanced-N 6200 AGN
Product Type Intel(R) Centrino(R) Advanced-N 6200 AGN
Installed Yes
PNP Device ID PCI\VEN_8086&DEV_4239&SUBSYS_13118086&REV_35\4&372A6B86&0&00E4
Index 15
Service Name NETwNs64
IP Address 192.168.0.25, fe80::e980:77f9:3453:6cb3
IP Subnet 255.255.255.0, 64
Default IP Gateway 192.168.0.1
DHCP Enabled Yes
DHCP Server 192.168.0.1
DHCP Lease Expires 3/8/2011 9:07 AM
DHCP Lease Obtained 3/7/2011 9:07 AM
Memory Address 0xF2400000-0xF24FFFFF
IRQ Channel IRQ 4294967294
Driver c:\windows\system32\drivers\netwns64.sys (13.4.0.9, 7.78 MB (8,153,088 bytes), 10/18/2010 3:21 AM)
Name [00000016] Microsoft Virtual WiFi Miniport Adapter
Product Type Microsoft Virtual WiFi Miniport Adapter
Installed Yes
PNP Device ID {5D624F94-8850-40C3-A3FA-A4FD2080BAF3}\VWIFIMP\5&17E78DDA&0&01
Index 16
Service Name vwifimp
DHCP Enabled Yes
Driver c:\windows\system32\drivers\vwifimp.sys (6.1.7600.16385, 17.50 KB (17,920 bytes), 7/13/2009 5:07 PM)
Name [00000017] Microsoft Teredo Tunneling Adapter
Adapter Type Tunnel
Product Type Microsoft Teredo Tunneling Adapter
Installed Yes
PNP Device ID ROOT\*TEREDO\0000
Index 17
Service Name tunnel
DHCP Enabled No
Name [00000018] Microsoft ISATAP Adapter
Adapter Type Tunnel
Installed Yes
PNP Device ID ROOT\*ISATAP\0002
Index 18
Service Name tunnel
DHCP Enabled No
I've renewed it's IP address, rebooted the PC and made sure the MoBo and PC have the latest firmware and drivers.
Your help is greatly appreciated.  Thanks!
5 Replies 5
rvaltier
Hi Kent
Seems to be a speed/duplex issue, could you check your PC's NIC advanced settings, check if it is set to auto, you may try also the other options available.
This is an example about NIC settings.
Rogelio V.
Rogelio,
Thank you for your reply.  The NIC is set to auto-negogiate the connection speed (from 10Mbps to 1Gbps Half and Full Duplex).  I switched it to 100 Mbps and I am getting great throughput again.  Thank you for the suggestion!
Ultimately, I'd like to be able to set it back to Auto because at my home network is wired for 1Gbps.  Is there a known issue with the phone having issues with negotiating with a 1 Gbps NIC?
Cheers,
Kent
Cisco: perhaps this is a bug that can be fixed in v7.4.8? :-)
I will check with engineering team, and I'll come back to you.
Rogelio V.
Kent,
I was wondering if you have  same issue with this computer in other phones or is just with this one.
regards
Rogelio V,
Rogelio,
The PC exhibits the same connectivity issue with each phone it is attached to so it seems its a problem with all SPA303 phones.  FWIW, other PCs connecting through the PC's "normal" phone (the one it'll connect through 99% of the time) have no Internet connectivity issues so its specific to the Lenovo X201 and its multibase.
Kent
