Here is my issue. I have a SPA509G with two extensions connected to a SPA9000/SPA400. EXT 1 (200) - works as described, caller calls in, phone rings 5x then transfers to voicemail. DND transfers to voicemail as well, and so does ...
Hi Guys,I was part of the beta testing for CCA and the software packs and have noticed that my comments and testing seem to have gone unheard. I see from the forums that there are other users experiencing the issues I reported. So why release softwar...
We have a client with a UC560 (8.0.5 software pack) using a SIP trunk for PSTN connection. Calls work fine. However, this client has been complaining about poor MoH sound quality. The SIP trunk is using G.729, so we're transcoding from G.711 for MoH ...
I want to upgrade my current VoIP configuration of a SPA9000/SPA400 with a UC520-8U-4FXO-K9. I am using SPA921 phones, are they compatible with the UC520? How difficult is the setup for the UC520, the SPA9000 was very simple and easy to use.
Cisco Unified Contact Center Express release 7.0 can integrate with CUCME on UC500. Please note that:a) This is tested for up to 12 users on UC500b) It requires advanced certification to be able to sell UCCXThe datasheet for UCCX is available athttp:...
Hello,I have a strange FXO Problem:In my test-environment I'm using a PAP2T to simulate POTS for the UC500 (UC520). With this I can pretty good reproduce a real world problem at one of my customers site:crackling in the voice connection (naming verif...
Salve ragazzi,è da 2 giorni che cerco di far funzionare il mio spa3102 ma non ci riesco.Vi spiego meglio la mia situazione.Ho comprato uno spa3102 , la mia esigenza è quella di remotizzare la mia linea telefonica telecom per utilizzarla anche nella...
First Let me show you the physical setup of my network.UC520 ------ ASA5505 ------ INTERNET -------- RVS4000 -------- SPA504 IP phonesIs there a way to get the two SPA504 IP phones from inside the RVS4000 remote office to tie into the UC520 throu...
Hi,yesterday I encountered a strange issue:1. removed DN 112 from phone (accidentally the national emergency number (112) was used as DN)2. added 124 to phone, everythin ok3. one phone had an issue with its display tried changing the MAC-...
I cannot for the life of me find where to change the message that is on every phone on a UC560 system using CLI. I know how to change it using the CCA but we are using out of band configurations on our UC560 and cannot use the CCA to make the change...
Hello!I have SPA8800 with predefined LAN ip with dhcp server on for 4 IPs.can I change LAN ip?
We have a UC560 (software pack 8.0.5), and are trying to get a CIPC softphone set up with it. The softphone works fine using the PC speakers/microphone, however when we try to use a Bluetooth headset (Jabra BT530) with it we get distorted audio. It's...
Hi,I am having problems with an ATA186. I have the ATA correctly registered with my UC560 and I can make calls from ip phones to analog phones connected to the ATA, but I can not make calls from analog phone to outside or even to another ip phones, i...
Hi all,I have this problem for my UC-520.the voicemail setup is done, and user can dial to the voicemail.but the problem is, when the system is asking the PIN number, whatever the button pressed by the user can't be processed by cisco unity express.a...
Anyone have a working CLI example of blocking an inbound FXO call based on Caller-ID? The UC540 was configured with the default CCA config and unfortunately not having much luck getting Call Reject to work from the command line.Thanks!
