Outgoing Caller-ID with SIP Service
jcarter
Level 4
Level 4
I have a customer using a NexVortex SIP trunk with their UC540.   When the setting on NexVortex says PBX Generated ID for Caller ID,  it shows up on the called side as unknown number.
I have the caller-id number entered in the caller-id section of CCA.
Anyone have an idea why this doesn't work?  They have 3 different phone numbers that need caller-id so I need the caller-id to come from the UC540.
5 Replies 5
Steven Holl
Can you collect the output of 'debug ccsip mess' from the router while a call goes out with the issue?
Also, you should call your provider and find out how they populate CLID.  Do they use the 'FROM' field?  Or RPID?
I attached the debug.
The provider is looking for 10 digit number as RPID.
Jason,
Do you have RPID disabled on the gateway?  There isn't an RPID in the INVITE.
I think remote caller id disabled by default.  I changed that.  I attached the updated debug.  It looks like it sends the calling extension as the remote caller id instead of the 10 digit number.
You can configure a dialplan pattern under telephony-service to expand to 10 digits (beware that this will affect the way the number is presented to CUE), or you can configure a outbound translation pattern on your SIP dial-peer to expande the calling number to a full 10 digits:
http://www.cisco.com/en/US/partner/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
