12-31-2010 02:33 PM - edited 03-21-2019 03:28 AM
In preparation for a UC540 deployment with PRI card the telco asked two questions that we were not sure about and wanted to see if anyone could shed some light one these questions
3. What is the number of Outpulsed Digits (digits we send to you from our Switch)?
4. Are there any unacceptable Lead Digits in the Outpulsed Digits?
Thank you in advance.
Solved! Go to Solution.
01-02-2011 02:51 PM
The number of accepted digits you accept depends on your dial plan. Outpulsed digits are the amount of digits the telco sends to you so that your gateway can process and route the call. If you use four digit extensions then you should accept four.
01-02-2011 02:51 PM
01-13-2011 06:45 PM
Thanks for confirming this.
