08-19-2009 01:54 PM - edited 03-21-2019 01:26 AM
ephone-dn 28
number 622
paging ip 239.1.1.2 port 2000
paging group 2
ephone 6
mac-address 0000.0000.0000
paging-dn 28
type 7921
button 1:10 2:11 3:12 4:13 6:2
When calling 622 from a 7965 I cannot recieve any pages on the 7921 phones. Any thoughts?
P.S. I installed a 7911 and inserted in the same paging-dn 28 and it works ok.
Solved! Go to Solution.
08-19-2009 02:47 PM
Doesn't look like multicast is supported on that AP. Marcos wrote an article describing the limitation.
https://supportforums.cisco.com/docs/DOC-9495
You'll need to change your paging from multicast to unicast to resolve the problem.
Cole
08-19-2009 02:26 PM
This is most likely due to the wireless network not passing multicast traffic. Are you using autonomous APs or lightweight?
Cole
08-19-2009 02:34 PM
The 7921s are working off (AIR-AP521G-A-K9). Reading more I see this is an autonomous ap that does not support multicast, or does it? I do not have a controller to turn this into a light weight...
08-19-2009 02:47 PM
Cole
08-20-2009 09:18 AM
Thanks for the information. We changed the paging to unicast and all works well.. Thanks again!
