Paging with SPA525G2 phones on Wi-Fi
mdrudholm
It appears that SPA525 phones on wifi can originate group pages, but they don't receive them.  Is this a known limitation or a bug?  In either case, is it something that will be made to work in the future?
Dan Lukes
Well, we are not using this kind of configuration, but as far as I know no one has reported issue like this one here so far.
Group page feature uses multicasts.
You should verify the multicasts are properly delivered thru your WiFi network to the SPA525Gs in question.
Dan Lukes
mdrudholm
I knew there were caveats with multicast on wifi (that I thought I had addressed).  Once I enabled IGMP Snooping on the AP, Paging started to work.  I'll leave this post up in case it helps someone.  IGMP Snooping allows the AP to track which wifi clients are interested in multicast streams so that it can deliver them.
Glad to hear you solved the issue.
You may consider to claim thread answered. It will help others to find answer.
