Phone template
Eivind Jonassen
Level 4
Level 4
Is it possible to create template for the softkeys on the 921 and 962 phone´s? Like on the UC520 there´s like a ephone-template configuration, does the SPA solution have the same possibility??
Is it possible to localize the 921 phone? I can only find documentation on the 922 phone.
Eivind Jonassen
Patrick Born
Hi Eivind,
The SPA phones' softkeys are not user-programmable.
The SPA9x1 phones do not have langauge localization features and only support English.
Patrick
Patrick Born
Hi Eivind,
Patrick
Hi Patrick,
I didn´t like the answer, but thanks for your reply :-)
regards
Eivind
