02-15-2010 06:55 AM - edited 03-21-2019 02:10 AM
has anybody successfully intergrated a polycom conferencing unit onto a UC540.
Polycom:
We absolutely cannot get this to register. If anybody's had success can you share your configs??
Please & thanks!
02-15-2010 08:43 AM
This document will give you the idea of what to do on the UC500 side.
https://supportforums.cisco.com/docs/DOC-9465
I haven't used this particular phone before, so I am not sure how it would work on the phone configuration side.
02-15-2010 10:02 AM
Thanks Steve,
Looks like that doc is for an anlog device. This polycom is a SIP device...
02-15-2010 11:06 AM
You are correct, but the process is the same. The analog device is a SIP endpoint. The UC500 doesn't know what type of device it is be configured. This guide would help get the config on the UC500 correct. The part that concerns the SPA8000 web page would be different. You would need to figure that part out on your polycom.
02-15-2010 12:12 PM
Perfect. We'll give this a try right now.
Thanks Steven
