Prior to Purchasing a BE6000
daniel0040
                   Hi, I'm looking to invest in a BE6000 but wanted to get something clear beofre I take the leap, Is there anything else I would need besides the BE6000, POE switches, IP Phones and SIP Trunk proivder? Out main routing device is a Sonicwall with QOS would this work or would I need to implament a Cisco Device?
Also Would you guys recommend putting this on our FIOS internet or a completley seperate FIOS Account?
niyates
Hello:
Your device is not supported by the Small Business Support Center. To get an answer to your post please post in the appropriate section (see below).
Also, you have a duplicate post, please be careful to limit similar issues / questions to one post to more accurately get answers to your questions.
You will most likely have better luck posting under Collaboration, Voice and Video > Unified Communications Applications
Hope this helps you get an answer!
~Nick
Cisco Network Support Engineer
~Nick Cisco Network Support Engineer Please mark answered for helpful posts!
