Hi Experts We have one SPA 3102 and one Analog line we want to extend that analog line to different location, i tried alot and but cant find the proper documnet for that which says how to program SPA 3102 as a SIP server, All documents says how to re...
Hi all,here is the configuration before changinadsl modem --> uc540(pppoe)then the customer wanted to have vdsl, but they didn´t get fast enough an modem so this was the configurationthey changed the firewall to no firewall settings and nat to no nat...
Ive been trying to put a miss call list softkey button during my idle screen I tried doing this"em_login|1;acd_login|1;acd_logout|1;avail|3;unavail|3;redial|5;dir|6;miss|7;psk1|8;lcr|9;pickup|10;gpickup|11;unpark|12;cfwd"but all it does is put an emp...
I'm configuring 4 SPA504G with expansion-module 500s in a UC560 system, and buttons on module with monitor/watch line or blf don't show LED. I see only red color for busy line. But available green led and orange ringing led? Any Bug or special confi...
As I've read though the support pages it appears that there are no current plans to include the ability to append a number to outbound calls when behind a pbx. Unfortunately I'm kind of stuck with that situation. I've managed to get an autodialer p...
Hi Folks,I have an SPA9000 and am wanting to setup the following ring strategy.Calls to reception (ext 100) should ring for 10 seconds then ring all extensions if there is still no answer then go to reception voice mail.I thought you could simply fo...
Hardware: SPA509G with SPA 500s add on modulePhone system: Kerio OperatorThis is the issue:Incoming Call 1 is placed on hold due to a 2nd incoming callAfter pickup of Call 2 xfer button turns into xferLxWhen we try to use xferLx it will take the two ...
We have a UC540 installed at the customer site and using SPA525 as phones.When receiving an external call the number is displayed in the following way 00005251354780. When using the redialing function it comes to error due to that redialing isn't pos...
I have several ip phones spa303, spa525 and spa508On the spa508 when the dnd is active there is no notification on the screen. The only way to know its on is to hit the > button to see if it says -dnd on the second pageOn the spa303 and the spa525 w...
When using the SPA302D caller ID for the number comes up as a series of x's. The display name is there (support, sales, Cameron) but the number below just shows as xxxxxxxxxxxxx. If you press call it does call the number but just displays the x's. Ho...
