07-30-2015 08:24 AM - edited 03-21-2019 10:27 AM
dear Experts,
i am facing problem to configure pap2t and spa3102 devices for PSTN & FAX line.
here is my scenario look into and give me your valuable feed back that what should i do.?
07-30-2015 02:34 PM
You have two problems, the analog phone and the fax machine. You should tackle the analog phone first and get that working.
The fax machine could be much more difficult. You may not be able to make the fax work at all. You will need to be using the G.711 codec. The FAX machine should be set to use the slowest setting possible. The SPA3102 / PAP2T Administration Guide has some suggestions for SPA3102 settings for FAX on page 50. These settings would also be true for the PAP2T. The Admin Guide also discusses the T.38 Fax relay standard. T.38 is not supported by the PAP2T and is only supported by the SPA3102's FXS port, not the SPA3102 FXO (line) port, so that discussion is not relevant in your case.
From your diagram you do not show any router, just fixed ip addresses. For a voip connection you should not be cabled to the internal local network router ("Ethernet" port) of the SPA3102. You need to be connected to the "Internet" port (WAN port) of the SPA3102. This was covered in the previous thread.
If you have tried configuring the units you should post the configurations and describe the test results. If you login to an adapter with a web browser you can save the configuration to your computer's hard drive. With the SPA3102 you need to login to Voice and save and then to Router and save. Make a .zip file of the saved configurations and attach to a posting.
07-31-2015 06:04 AM
thanks both of you.
i hear dial tone but when i dial any number dial tone change into busy tone.
below i upload my both devices configurations.
after this configuration when i dial a number to my mobile from pap2t it had fine and i get call from pap2t but when i dial any other number tone change into busy tone.
have a look my configuration and told me that where is problem and mistake...
advance thanks.
07-31-2015 03:08 PM
You should follow Howard's advices at the first. If it will not help, then ...
Busy tone may have so many causes.
You need to identify cause. TUrn on syslog&debug messages on PAP2T and catch them. Catch SIP packets between PAP2T and SPA3102 as well.
It should reveal information important for further analysis of the issue.
07-31-2015 04:33 PM
You need to login to your SPA3102 again under the "Voice" Tab and save and post the configuration like you did previously under the "Router" tab so we can see how you have configured the SPA3102 PSTN Line Tab.
You do not have a conventional network with a router that directs packets. If I understand correctly your network is point to point between the PAP2T and the SPA3102. There is no connection to the internet.
You have setup the SPA3102 with a Static IP address of 192.168.1.88. In this case the ip address of the PSTN Line Tab would be 192.168.1.88:5061 assuming 5061 is configured as the Sip Port: on the PSTN Line Tab.
On the PAP2T you have Line 1 disabled and Line 2 enabled. I assume you have the analog phone connected to Line 2. On Line 2 you need to change Register: yes to Register: no before you can make a call. You have the dial plan as follows:
(<#9:userid@192.168.1.88:5060>|xx.)
I imagine dialing #9 would call the phone attached to the SPA3102 assuming the Line 1 Tab User ID is userid and the sip port number for the Line 1 Tab is 5060. I can duplicate that when I have two ata's connected with either regular cable or a crossover cable. It should work for you.
With your dial plan, dialing some number other than #9 would send that number to what you have setup as the Proxy, i.e. 192.168.1.88:5061, and since the number does not match the user id of port 5061 the SPA3102 should bridge that call to the PSTN line. I can duplicate that, bridging the call to the PSTN line, when I have the two ATA's attached directly with a regular cable or a cross-over cable. It should work for you.
So, change the Register: Yes setting to Register: No on the PAP2T Line 2 Tab and also post the SPA3102 Voice Tab configuration.
Edit: I believe the Register setting was what was stopping your call from the PAP2T.
07-31-2015 06:56 PM
07-31-2015 07:37 PM
07-31-2015 10:01 PM
So the network is conventional with a router. You have the SPA3102 setup with a static ip address of 192.168.1.88 but show it on the diagram as 192.168.1.3. Any particular reason for that?
07-31-2015 10:14 PM
08-01-2015 08:21 AM
08-06-2015 08:34 PM
08-06-2015 09:31 PM
The PAP2T configuration looks OK assuming you changed the static ip configuration of the SPA3102 to 192.168.1.103. You previously had it set to another address. By putting the configuration in .pdf format, you did not include the SPA3102 INFO Tab or the Router Tabs which would tell me the SPA3102 ip address and the voltage level of the attached pstn line. When you save the configuration with your web browser you get all the tabs with one save when logged into Voice Tab and one save when logged into the Router Tab.
On the SPA3102 you have the SPA3102 PSTN Caller Default DP set to 1 which is (xx.). This will return a dial tone to the PSTN caller. You should have it set to 2 which is (S0<:userid@192.168.1.104:5061) which will immediately dial the distant PAP2T assuming the PAP2T ip address is 192.168.1.104.
On the SPA3102 you have PSTN Ring Thru Line 1: YES and PSTN Answer Delay: 16 which will attempt to ring the phone (that does not exist on your diagram) attached to the SPA3102 for 16 seconds before accessing the PSTN-to-VoIP Default Caller DP which would ring the distant PAP2T.
On the SPA3102 you have the SPA3102 Line 1 VoIP Caller DP set to 2 which is (S0<:userid@192.168.1.104:5061). This applies to a phone attached to the SPA3102 which you do not show on your diagram so I guess it is not important, however it won't work.
08-19-2015 11:19 PM
Dear Harword,
i am so sorry for late reply because of busy schedule.
i am still facing that problem.when i dial any no after 5 seconds i have received busy tone from pap2t.
if i get off RJ11 connector from spa3102 than i hear same busy tone.
please make it easy for me.
thanks
08-20-2015 10:59 AM
It would help to see the current SPA3102 and PAP2T configurations.
Explain what does work and what does not work.
Your problem could be the detection of a disconnect of your attached PSTN Line to the SPA3102.
When your PSTN disconnects the line it must send a disconnect tone that you have configured, or give a CPC signal (voltage drop) or you must do it by detecting silence on the line for a configured period of time. These are configuration settings.
08-20-2015 10:59 AM
What should i do???
