12-05-2011 09:41 AM - edited 03-21-2019 05:02 AM
Hello all,
is there a way to add an extra line of information on the
SPA508G terminal when it's recieving a call? (with Asterisk)
Default it says for example:
31123456789
I hope to add an extra line of info so the terminal owner can
see from which queue this call is comming from.
31123456789
Queue - Tech Support
ThX!
12-09-2011 04:39 PM
The info is populated from the SIP Invite which usually contains the name and number in that Invite.
The options available are located in the SIP tab under SIP Parameters, Caller ID header. You'll see PAID-RPID-FROM.
Details in the admin guide about what these mean. Link is
12-13-2011 02:07 AM
My phone gives me 5 chooses:
BUT when I choose option 1 (P R F) or option 3 (R P F) the phone won't show the
three lines of information I want. Because it sticks with diplaying only 2 line...!
Dispite there is one line totally empty!
So I know how I can change the information (P, R & F) send to the phone.
But how can I get the phone to display ALL three lines at ones when the phone is ringing!?
12-22-2011 05:32 AM
BumB!
Nesto!?
12-22-2011 08:40 AM
Those choices of three, allows you to pick one of those three. You won't see the Queue Tech Support since that's not part of the From or Asserted ID information in the SIP Invite.
