08-12-2010 10:08 AM - edited 03-21-2019 02:51 AM
hi,
i am currently have 4 scripts already on uc520, and i can't add another one ( it reaches the maximum limit).
what is the limitation on the script, and how do i add more scripts when it reaches the maximum limit
thank you
08-12-2010 11:15 AM
MAX AA Scripts is 12 in the latest SW release of CUE.
08-12-2010 11:19 AM
Does it inlcude the system script or just the custom ones?
08-12-2010 11:21 AM
both are included. You can add or delete scripts using CUE GUI (browser to 10.1.10.1) and they will show up in CCA AA script management to assing as well.
08-12-2010 11:30 AM
are we able to delete system scripts?
08-12-2010 11:34 AM
As long as they are not being used, you can try. I never did this....
08-13-2010 07:47 AM
how about on uc540 or uc560, what is the maximum scripts allowed?
