set cfwdall remotely
Barry Hunsinger
is there a way to change call forward all on a cu500 from outside the office?
Ryan-Kramer
This can be completed using the CLI.
Under the users ephone-dn, you would enter the following:
call-forward all 201
Where 201 is the extension I am call forwarding to.
David Trad
Hi Barry,
If you have remote access via VPN then you can use Office Manager, which ideally would be a better option than CLI configuration.... Do you have VPN access direct to the UC?
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
