Setting default audiooutput on SPA525G2 IP Phone
vidar.lunde
When I answer a call on my bluetooth headset connected to the SPA525G2 ip phone and put the call on hold either using the hold button under the display or the "Hand" button, and then use the same buttons to resume the call, the audio always jumps to speakerphone and not back to my headset.
Is there a way to make my headset the default audiodevice and not the speakerphone?
Can't find this setting in the user manual.
Dan Lukes
Well, I have no SPA525G2 near just now, but unless there's a configuration for it (I'm expecting it in "User" tab, "Audio" section)  it's not possible to configure it.
The behavior you described I consider firmware bug. Upgrade to latest firmware version if possible. Call SMB Support center and report it/ask for help otherwise.
