06-12-2011 06:07 PM - edited 03-21-2019 04:13 AM
Hi Forumers'
Would like to ask is it possible to use UC560+SPA525 UC combo and supoprt the PVC2300 video surveillance camera to act as a internet camera, another alternative way doing tele-presence.
want to use the PVC2300 it's more flexible to install the camera at open position.
thannks for all the feedback and idea.
Noel
06-12-2011 07:18 PM
This will definitely work. Although it might be more flexible and convenient to use a Webex type solution.
Cole
06-13-2011 04:07 AM
hi cole,
thanks for reply. Just can you show me where i can get the official documentation talking on this matter? really appreciate with it
thanks.
Noel
06-13-2011 07:08 AM
Noel,
525/2300 setup:
https://supportforums.cisco.com/docs/DOC-9825
Shold be able to use SSL if you want to bring the 525 offsite.
https://supportforums.cisco.com/docs/DOC-9811
You can view the 2300 remotely by setting up Static Nat. Maybe that helps you more....
Surf to the camera, 192.168.10.150 or whatever your camera's IP is...
Setup > Advanced Setup - Enable HTTPS checkbox, use 10123 port. Save.
Audio/Video > Video - Enable Mobile Streaming checkbox, type in an access code (eg., 123456). Save.
You can test it via Quicktime by opening URL: rtsp://192.168.10.150/123456
Now set up for remote viewing...
In CCA > Security > NAT, click "create" under "Static NAT" adding:
TCP, Inernal 192.168.10.150 port tcp 10123, external (your wan address) port tcp 10123
TCP, Inernal 192.168.10.150 port tcp 554, external (your wan address) port tcp 554
Test this outside of CCA/UC500 from the internet by using Quicktime > open URL, then rstp to the wan, e.g.:
rstp://62.44.33.11/123456
You should also be able to surf to the camera via the wan port address of the uc500:
https://62.44.33.11 using your vpn credentials
Then you need to type the camera's ip in the url field: 192.168.10.150
Brian
