08-15-2011 12:56 AM - edited 03-21-2019 04:30 AM
Hello everyone,
we have a new setup with asterisk (1.6) and some SPA 303 phones.
There is a configuration on asterisk, which allows to programm call-redirections from the phone.
With a softphone i was able to programm call-redirections by dialing *440 or *450 etc.
But when i dial this from the SPA 303 the call is answered after dialing the first 3 keys (*44 or *45 etc.).
Also i'm not able to make transfers via keys given in features.conf (#[ext] or [*ext]).
So, the question is, how can i setup the phone / asterisk correctly?
Does somebody have a good example-configuration for SPA 303 with asterisk (Phone-Config + asterisk sip.conf)
Would be great.
Thanks!
08-17-2011 07:35 PM
SPA phones are Small Business products.
Try posting your question here -
08-17-2011 10:40 PM
Usually SPA phones do have vertical service activation codes that starts with *(asterisk). Check out the configuration manual. I dont have a 303 phone. But most SPA phones do have options to change it via web interface. Refer manual for and change that doesnt clash with your dialplan.
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpipp/ip_phones/user/guide/spa300_sip.pdf
08-18-2011 02:14 AM
Thanks for your Replys,
i could solve the Problem yesterday. I had to change the Dialplan for the Extension.
The Standard-Dialplan accepts only two digits after *, cause of the pattern "*xx". If no other pattern can match the dialed numbers, the phone places the call automatically. I changed the Dialplanentry to "*x." and now it works!
