SPA 112/122 FW 1.1.0 (011) provisioning problem
burger.tomas
I have problem with provisionig Cisco SPA 112/122 after upgrade FW to 1.1.0 (011).
Is there any solution or just we should not use this FW?
We use provisioning by entering url to
Profile Rule:   http://prov.802.cz/prov.xml
set short times and Submit, but nothing happens :-(
After downgrade FW to 1.0.1 (022) provisionign work with no problem.
Thanks for your advice
Tomas
nseto
Level 6
Level 6
We have identified some provisioning issues and those are fixed in the upcoming release which should be out on cisco.com in the next 2 weeks.  Thank you.
