07-12-2015 03:26 AM - edited 03-21-2019 10:26 AM
I've got no idea if I'm in the correct place to get an answer, but I'll post my question.
I have an SPA112 which is connected to my network and my Philips DECT telephone for Skype. The telephone cannot get access to the phone network. The lamp on the SPA blinks green but nothing is heard.
I tried calling the SPA to get the ip address but it gives an address of 0.0.0.0 which I cannot connect to!
So how do I get the box to work ?
A solution would be gratefully appreciated.
Peter
07-12-2015 03:56 AM
Read THIS.
07-20-2015 07:35 PM
This discussion has been reposted from Additional Communities to the ATAs, Gateways and Accessories community.
07-21-2015 12:51 AM
0.0.0.0 is no valid IP address. It is "no address known" address instead.
As the very first step you need to configure the network connectivity on your SPA112.
Exact method depend on overall configuration of your's LAN which we know nothing about. Ask your local network administrator (e.g. the one who configured your local network) for help.
You will be able to continue with further configuration steps then.
