SPA 3102 Send DTMF tone on PSTN pick-up?
jamesfera
Is it possible to automatically send a DTMF tone (or series of tones) when the PSTN line is picked up by the SPA 3102?
I currently have PSTN to VOIP forwarding working correctly but in this setup I have to manually pick up the forwarded line and dial the keys myself.  I would like to skip this step and have the SPA automatically dial for me without the use of a SIP provider.
Thanks in advance.
You can setup the PSTN Caller Default DP (Dial Plan) to automatically dial the voip leg of the call when the SPA3102 answers the incoming PSTN Line call. For example a dial plan of (S0<:19251234567) will automatically send the stated number to your configured proxy server.
If your question is, however, can you automatically dial dtmf digits after the voip leg of the call connects I do not know of any way to do that.
