SPA 525G SSL VPN
gstreet
I was wondering if I set up a SSL VPN on UC520 on a non-default port, say 44300, where do I enter that information in on an SPA525G?
Loooking into this option as as the system is currently setup the certificate presented by an internal server is throwing "Failed to validate server certificate" error, which I believe is because the certificate is issued against a public IP and not the server internal IP.
Cheers
Gideon
gstreet
I was able to answer my own question, for reference, specifying a non-standard SSL port on a 525G is the same as you'd use in a browser,
"x.x.x.x:"
Cheers
