SPA112 inbound ring tone too short
info
Hi there,
I use an SPA112 with a SnomONE PBX. On an inbound call the phone rings only for some milliseconds at the beginning of each ring signal.
Is there an option to adjust the ring signal length in SPA112 configuration?
Thanks a lot,
Philip
Dan Lukes
It seems not to be PBX versus SPA112 issue but SPA versus yours-analog-phone issue. The ringing signal on POTS is driven by Ring_Waveform, Ring_Frequency, Ring_Voltage. You need to configure it according your's analog phone requirements.
Dan Lukes
Thanks a lot. It seems to work now. Somtimes, things are easy to solve if you know how...
