04-12-2013 08:44 PM - edited 03-21-2019 10:02 AM
Hi All,
I have an SPA112 and its all configured to work as per my network settings. However, it keeps cutting out the line after every minute. Not sure what the real problem is. I've updated the firmware to the latest..still the same thing...Any thoughts, anyone?
04-15-2013 03:38 PM
I'm assuming that you mean call drops after a minute.
We'd need to see the sip debug log to see if there's a bye being sent out or coming into the device.
04-15-2013 06:41 PM
Hi Nseto,
Thank you for the advise. I've attached the debug log as requested. Let me know if there's something that stands out to you.
syslog server(port:514) started on Tue Apr 16 11:23:23 2013
Firmware downgrade limit()
httpd_handle_request(), request method = 1
httpd_handle_request(), request path = /admin/voice/
httpd_handle_request(), pswlReq->ubType = 0
Requesting call statistics...
Call statistics updated.
httpd_handle_request(), request method = 2
*** show dtmf tx holdoff time 70 for line 0
*** show dtmf tx holdoff time 70 for line 1
get_dhcp_option66_67_info, voice interface is 'br0'
uch_syncParameter start
uchInitDTMFTbl(), dtmf level -160
uchEnableEchoCan(), lid 0 EP 2 enable
UCH sync parameter hold off time is 70
uch_syncParameter(), uch_syncDTMFHoldOffTime(0)=0
uchEnableEchoCan(), lid 1 EP 1 enable
uch_syncParameter(), uch_syncDTMFHoldOffTime(1)=0
[0]<<31.6.78.124:5060(499)
OPTIONS sip:6010@60.240.77.7:5060 SIP/2.0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK100c9cd0;rport
To: <6010>6010>
Contact:
Call-ID: 1733ac8555ee10d9107aa9e72904bfe2@31.6.78.124
CSeq: 102 OPTIONS
User-Agent: Asterisk PBX
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:27:34 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Supported: replaces
Content-Length: 0
[0]->31.6.78.124:5060(400)
SIP/2.0 200 OK
To: <6010>;tag=e86c9e9a830a9c1ei06010>
CSeq: 102 OPTIONS
Server: Cisco/SPA112-1.0.2(006)
Content-Length: 0
Allow: ACK, BYE, CANCEL, INFO, INVITE, NOTIFY, OPTIONS, REFER
Supported: replaces
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK6f447a66;rport
To: <6010>6010>
Contact:
Call-ID: 46304d8b50a8ac2b199f8f271ca9b47e@31.6.78.124
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:28:34 GMT
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length: 0
Supported: replaces
[0]<<31.6.78.124:5060(849)
INVITE sip:6010@192.168.1.41:5060 SIP/2.0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK276264bc;rport
From: "Frankston South, Australia" <6004>;tag=as5e9562286004>
To: <6010>6010>
Contact: <6004>6004>
Call-ID: 622b7b5371f983216189622f2e21e12b@31.6.78.124
CSeq: 102 INVITE
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:28:54 GMT
Supported: replaces
Content-Type: application/sdp
Content-Length: 305
v=0
o=root 2809 2809 IN IP4 31.6.78.124
s=session
c=IN IP4 31.6.78.124
t=0 0
m=audio 10582 RTP/AVP 97 0 8 101
a=rtpmap:97 iLBC/8000
a=fmtp:97 mode=30
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
[0]->31.6.78.124:5060(312)
SIP/2.0 100 Trying
To: <6010>6010>
CSeq: 102 INVITE
Content-Length: 0
CC_eventProc(), event: CC_EV_SIG_CALL_ARRIVED(0x2F), lid: 0, par: 0, par2: 0x40324a28
AUD_ccEventProc: event 47 vid 0 par 0x0 par2 0x40324a28
pconly: 0
CC:pc(0)=130 not in codec list
CC:pc(1)=18 not in codec list
clRemote: 0x40324ab8, clLocal->ucNumAudioCodec: 2
[AUD]Get UCH node for AUD_LINE 0.
uchAllocateNode(), Node 0 allocated
[AUD]UCH node 0 allocated to AUD_LINE 0.
uchConnectEpToNode(), connecting EP FXS 1 to node 0
uchEnableNode(), Node 0 enbaled
CC_eventProc(), inf.strName = Frankston South, Australia
CC_eventProc(), inf.strPhone = 6004
callEventProcTable[0] is cepIdleProc
cepIdleProc(line=0x1c6528, call=0x1c652c, event=18(CC_EV_USR_ACCEPTCALL), par=0, par2=0x40324a28)
cepIdleProc(), lid=0
cepIdleProc(), line->sigProc(CC_CMD_ACCEPT)
cepIdleProc(), call->cinf.bAutoAnswer = 0
NEW_CALL_STATE(), call 0: old state = 0, new state 5
CC_eventProc(), msg CC_EV_USR_ACCEPTCALL(92) sent to CC
[0]CID:CID_initGen() >>> offhook 0 delay 2200 phone 6004 name Frankston South, Australia
SLIC_startRing state 0 ts 0x1ed790on 2000 off 4000 len 60000
[0]Ring cad event 0 pol 0
RTP_nextMediaPort(), port = 16392
RTP_nextMediaPort(), rc=16390
AUD_allocCallObj() call(0x1ef7c0)
[0:0]AUD ALLOC CALL (port=16390)
[AUD]AUD_startRtpRx(0x1ef7c0)
Local loopback mode: None. Type: None.
Remote loopback mode: None. Type None.
RTP channel setup: udp_no_checksum 0, sysmmetric_rtp 0, tos 0xb8, cos 6, mlb 0.
uchConnectEpToNode(), connecting EP VoIP 0 to node 0
cordless_start_rtp(), chan:0 remote ip:(null) port:0 local:16390 rx:1 ipt:0 ptime:0
Starting Rx only RTP.
Socket 19 bound to port 16390.
Remote IP/port: 0.0.0.0:0
Codec list from SDP (internal pt):Codec list from SDP (internal pt): 0 0 8 8 134 134 136 136
Rx payload list: Rx payload list: PCMU/8000(0) PCMU/8000(0) PCMA/8000(8) PCMA/8000(8) NSE/8000(100) NSE/8000(100) encaprtp/8000(112) encaprtp/8000(112)
set RTP_SESSION_OPT_DTMF
RTP configuration:
audio_mode RTP_MODE_REC_ONLY, media_loop_level RTP_LOOP_LEVEL_NONE, dtmf2833numEndPakcets 3, opts 0x0
Codec: duration 0, rx_pt_event 101, tx_pt_event 101, tx_pt 0
rx[0] 0 PCMU/8000, rx[1] 8 PCMA/8000, rx[2] 100 NSE/8000
rx[3] 112 encaprtp/8000, rx[4] -1 , rx[5] -1
Jib: max 180ms, min 60ms, adapt 1
RTP Channel 0 is virgin: 1.
RTP session 0 started
uchSetDTMFMute(), ENABLE
[AUD]RTP Rx Up
SIP/2.0 180 Ringing
To: <6010>;tag=93d9d48c852dff3ei06010>
CSeq: 102 INVITE
Contact: "Brahma Kumari Canberra" <6010>6010>
Content-Length: 0
Set QoS succeed
[0]Ring cad event 1 pol 0
CID:OnHookTx Pol
[0]CID CID_ST_POLREV_POST_DELAY
uchDisplayCIDFSK(), EP 2 lid 0 buflen 107 overhead 60 SZ_MAX_USERDATA 200
[0]CID Start DTMF/FSK, CID_ST_ACTIVE
[0]CID CID_ST_FSK_COMP_DELAY
[0]CID CID:DONE
[0]CID CID_ST_ACTIVE_POST_DELAY
[0]CID CID_ST_IDLE
[0]Off Hook
CC_eventProc(), event: CC_EV_USR_OFFHOOK(0x2), lid: 0, par: 0, par2: (nil)
AUD_ccEventProc: event 2 vid 0 par 0x0 par2 0x0
sysstatus_set_led_status_payton(), led_id: 1, statusCode:7, systemEvent: 0x100095
callEventProcTable[5] is cepRingingProc
NEW_CALL_STATE(), call 0: old state = 5, new state 7
SLIC_stopRing
[0]Ring cad event 2 pol 0
SLIC_stopRing
SLIC_stopTone
[0]->31.6.78.124:5060(763)
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 251
Supported: replaces
v=0
o=- 96219 96219 IN IP4 192.168.1.41
s=-
c=IN IP4 192.168.1.41
t=0 0
m=audio 16390 RTP/AVP 0 100 101
a=rtpmap:100 NSE/8000
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 251
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 251
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<31.6.78.124:5060(401)
ACK sip:6010@60.240.77.7:5060 SIP/2.0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK683598f6;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP_sessDlgEventProc: event: 42, ucState: 0
CC_eventProc(), event: CC_EV_SIG_CALL_CONNECTED(0x2A), lid: 0, par: 2, par2: (nil)
AUD_ccEventProc: event 42 vid 0 par 0x2 par2 0x0
callEventProcTable[7] is cepAnsweringProc
cepAnsweringProc(line=0x1c6528, call=0x1c652c, event=42(CC_EV_SIG_CALL_CONNECTED), par=2, par2=(nil))
CC:Connected
NEW_CALL_STATE(), call 0: old state = 7, new state 8
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
[AUD]AUD_startRtpTx(0x1ef7c0, 0, 31.6.78.124, 10582, 20)
Already has a RTP channel.
cordless_start_rtp(), chan:0 remote ip:31.6.78.124 port:10582 local:16390 rx:0 ipt:0 ptime:20
Going from Rx only to bi-directional.
Old remote IP/port: 0.0.0.0:0
Remote IP/port: 31.6.78.124:10582
RTP configuration:
audio_mode RTP_MODE_ACTIVE, media_loop_level RTP_LOOP_LEVEL_NONE, dtmf2833numEndPakcets 3, opts 0x0
Codec: duration 20, rx_pt_event 101, tx_pt_event 101, tx_pt 0
RTP Channel 0 is virgin: 0.
Need to stop RTP session then restart.
[AUD]RTP Tx Up
[AUD]AUD_startRtcpTx(0x1ef7c0)
cordless_start_rtcp(), chan:0 remote ip:31.6.78.124 port:10583 intvl:0
Socket 26 bound to RTCP port 16391.
CNAME 6010@192.168.1.41
NAME "Brahma Kumari Canberra"
TOOL Cisco/SPA112-1.0.2(006)
Starting RTCP session on channel 0. Interval 0. Rx only.
RTCP session started on RTP channel 0.
[AUD]RTCP Up
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK22a27136;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK015e71ac;rport
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
[0]<<31.6.78.124:5060(368)
BYE sip:6010@60.240.77.7:5060 SIP/2.0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK2acff592;rport
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
[0]->31.6.78.124:5060(328)
SIP/2.0 200 OK
CSeq: 103 BYE
Content-Length: 0
SIP_sessDlgEventProc: event: 44, ucState: 3
CC_eventProc(), event: CC_EV_SIG_CALL_ENDED(0x32), lid: 0, par: 2, par2: (nil)
AUD_ccEventProc: event 50 vid 0 par 0x2 par2 0x0
callEventProcTable[8] is cepConnectedProc
cepConnectedProc(line=0x1c6528, call=0x1c652c, event=50(CC_EV_SIG_CALL_ENDED), par=2, par2=(nil))
CC:Ended
NEW_CALL_STATE(), call 0: old state = 8, new state 6
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
RTP TX stats updated for channel 0
RTP RX stats updated for channel 0
AUD_releaseCallObj() call(0x1ef7c0)
[AUD]AUD_stopRtpTx(0x1ef7c0)
cordless_stop_rtp_tx(), Channel 0.
RTP channel 0 going from Bi-dir to Rx.
RTP configuration:
RTP channel 0 is now Rx.
[AUD]RTP Tx Down
[AUD]AUD_stopRtpRx(0x1ef7c0)
cordless_stop_rtp_rx(), Channel 0.
RTP channel 0 going from Rx to Idle.
RTP configuration:
audio_mode RTP_MODE_INACTIVE, media_loop_level RTP_LOOP_LEVEL_NONE, dtmf2833numEndPakcets 3, opts 0x0
RTP channel 0 is now Idle.
[AUD]RTP Down
[AUD]AUD_releaseRtp(0x1ef7c0)
cordless_stop_rtp(), releasing RTP channel:0
cordless_stop_rtp(), RTP session 0 stopped succussfully
uchDisconnectEpFromNode(), disconnecting EP VoIP 0 from node 0
[AUD]RTP channel released
[0:0]AUD Rel Call
[AUD]Release UCH node for AUD_LINE 0.
uchDisableNode(), Node 0 released
[AUD]UCH node 0 freed.
Set QoS succeed
callEventProcTable[6] is cepInvalidProc
cepInvalidProc(line=0x1c6528, call=0x1c652c, event=30(CC_EV_TMR_INVALID), par=0, par2=(nil))
SLIC_stopRing
SLIC_startTone 8
uchSetMute(), ENABLE
uchSetMute(), DISABLE
DLG Terminated 255aa4
SIP_sessDlgEventProc: event: 40, ucState: 4
Sess Terminated
AUD_LINE 0 has no associated UCH node.
[0]On Hook
CC_eventProc(), event: CC_EV_USR_ONHOOK(0x1), lid: 0, par: 0, par2: (nil)
AUD_ccEventProc: event 1 vid 0 par 0x0 par2 0x0
sysstatus_set_led_status_payton(), led_id: 1, statusCode:1, systemEvent: 0x100093
cepInvalidProc(line=0x1c6528, call=0x1c652c, event=1(CC_EV_USR_ONHOOK), par=0, par2=(nil))
cepIdleProc(line=0x1c6528, call=0x1c6734, event=1(CC_EV_USR_ONHOOK), par=0, par2=(nil))
[IVR_eventProc] evt 1 lid 0
cepInvalidProc(line=0x1c6528, call=0x1c652c, event=10(CC_EV_USR_ENDCALL), par=0, par2=(nil))
NEW_CALL_STATE(), call 0: old state = 6, new state 0
SLIC_stopRing
SLIC_stopTone
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK51f45b89;rport
To: <6010>6010>
Contact:
Call-ID: 48220af52372c36b259c97a75d32e0c3@31.6.78.124
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:29:35 GMT
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length: 0
Supported: replaces
CC:Clean Up
NEW_CALL_STATE(), call 0: old state = 0, new state 0
NEW_CALL_STATE(), call 1: old state = 0, new state 0
NEW_CALL_STATE(), call 2: old state = 0, new state 0
--- OBJ POOL STAT ---
OP:TIMEOU = 67 (120 52) OP:SIPCOR = 0 ( 1 28)
OP:SIPCTS = 32 ( 32 936) OP:SIPSTS = 32 ( 32 6408)
OP:SIPAUS = 6 ( 8 680) OP:SIPDLG = 10 ( 10 148)
OP:SIPSES = 12 ( 12 9124) OP:SIPREG = 3 ( 4 468)
OP:SIPLIN = 0 ( 13 140) OP:SUBDLG = 13 ( 13 6444)
OP:STUNTS = 16 ( 16 68)
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK12d518b2;rport
To: <6010>6010>
Contact:
Call-ID: 3aaf92ba2a3d836e4151f20d62df4ffc@31.6.78.124
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:30:35 GMT
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length: 0
Supported: replaces
[0]Off Hook
[IVR_eventProc] evt 2 lid 0
cepIdleProc(line=0x1c6528, call=0x1c652c, event=9(CC_EV_USR_SEIZURE), par=0, par2=(nil))
cepIdleProc(), pname=voip-asia.brahmakumaris.org
cepIdleProc(), SYS_NOREG_CALL(0)=0, SIP_REGISTER_OK(0)=1
NEW_CALL_STATE(), call 0: old state = 0, new state 1
SLIC_stopRing
SLIC_startTone 1
Set QoS succeed
uchAppCb(), Event 37 received EP 2 lid 0
line:0 DTMFON event received digit 0
EVQ_read: 1 0 in 2024092
EVENT_DTMFON 0
CC_eventProc(), event: CC_EV_USR_DTMFON(0x4), lid: 0, par: 48, par2: (nil)
AUD_ccEventProc: event 4 vid 0 par 0x30 par2 0x0
uchAppCb(), Event 38 received EP 2 lid 0
line:0 DTMFOFF event received digit 0
EVQ_read: 0 0 in 2024092
EVENT_OOB_DTMF 0
CC_eventProc(), event: CC_EV_USR_OOB_DTMF(0x8), lid: 0, par: 48, par2: 0x64
AUD_ccEventProc: event 8 vid 0 par 0x30 par2 0x64
callEventProcTable[1] is cepDialingProc
cepDialingProc(line=0x1c6528, call=0x1c652c, event=8(CC_EV_USR_OOB_DTMF), par=48, par2=0x64)
cepDialingProc(), event = 8(CC_EV_USR_OOB_DTMF)
cepIdleProc(line=0x1c6528, call=0x1c6734, event=8(CC_EV_USR_OOB_DTMF), par=48, par2=0x64)
SLIC_stopRing
SLIC_startTone 1
EVENT_DTMFOFF 0
CC_eventProc(), event: CC_EV_USR_DTMFOFF(0x5), lid: 0, par: 48, par2: (nil)
AUD_ccEventProc: event 5 vid 0 par 0x30 par2 0x0
[IVR_eventProc] evt 5 lid 0
cepDialingProc(line=0x1c6528, call=0x1c652c, event=5(CC_EV_USR_DTMFOFF), par=48, par2=(nil))
cepDialingProc(), event = 5(CC_EV_USR_DTMFOFF)
cepDialingProc(), digit = 0
cepDialingProc(), dn = (null)
cepIdleProc(line=0x1c6528, call=0x1c6734, event=5(CC_EV_USR_DTMFOFF), par=48, par2=(nil))
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFON 0
EVENT_OOB_DTMF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFOFF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
line:0 DTMFON event received digit 4
EVQ_read: 1 4 in 2024092
EVENT_DTMFON 4
CC_eventProc(), event: CC_EV_USR_DTMFON(0x4), lid: 0, par: 52, par2: (nil)
AUD_ccEventProc: event 4 vid 0 par 0x34 par2 0x0
line:0 DTMFOFF event received digit 4
EVQ_read: 0 4 in 2024092
EVENT_OOB_DTMF 4
CC_eventProc(), event: CC_EV_USR_OOB_DTMF(0x8), lid: 0, par: 52, par2: 0x64
AUD_ccEventProc: event 8 vid 0 par 0x34 par2 0x64
cepDialingProc(line=0x1c6528, call=0x1c652c, event=8(CC_EV_USR_OOB_DTMF), par=52, par2=0x64)
cepIdleProc(line=0x1c6528, call=0x1c6734, event=8(CC_EV_USR_OOB_DTMF), par=52, par2=0x64)
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFOFF 4
CC_eventProc(), event: CC_EV_USR_DTMFOFF(0x5), lid: 0, par: 52, par2: (nil)
AUD_ccEventProc: event 5 vid 0 par 0x34 par2 0x0
cepDialingProc(line=0x1c6528, call=0x1c652c, event=5(CC_EV_USR_DTMFOFF), par=52, par2=(nil))
cepDialingProc(), digit = 4
cepIdleProc(line=0x1c6528, call=0x1c6734, event=5(CC_EV_USR_DTMFOFF), par=52, par2=(nil))
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
cepDialingProc(line=0x1c6528, call=0x1c652c, event=32(CC_EV_TMR_DIALPLAN), par=0, par2=(nil))
cepDialingProc(), event = 32(CC_EV_TMR_DIALPLAN)
cepDialingProc(), dn = 004
[checkSuppFeatActCode] lid 0 vid 0
pconly: 0
clRemote: (nil), clLocal->ucNumAudioCodec: 4
AUD_LINE 0 already has UCH node 0.
NEW_CALL_STATE(), call 0: old state = 1, new state 3
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
Calling:004@voip-asia.brahmakumaris.org:0, rc=0
RTP_nextMediaPort(), port = 16394
RTP_nextMediaPort(), rc=16392
[0:0]AUD ALLOC CALL (port=16392)
cordless_start_rtp(), chan:0 remote ip:(null) port:0 local:16392 rx:1 ipt:0 ptime:0
Socket 19 bound to port 16392.
Codec list from SDP (internal pt):Codec list from SDP (internal pt): 130 130 18 18 0 0 8 8 134 134 136 136
Rx payload list: Rx payload list: G.726/8000(2) G.726/8000(2) G.729/8000(18) G.729/8000(18) PCMU/8000(0) PCMU/8000(0) PCMA/8000(8) PCMA/8000(8) NSE/8000(100) NSE/8000(100) encaprtp/8000(112) encaprtp/8000(112)
RTP configuration:
Codec: duration 0, rx_pt_event 101, tx_pt_event -1, tx_pt 0
rx[0] 2 G.726/8000, rx[1] 18 G.729/8000, rx[2] 0 PCMU/8000
rx[3] 8 PCMA/8000, rx[4] 100 NSE/8000, rx[5] 112 encaprtp/8000
[AUD]RTP Rx Up
[rse_refresh_addr_list] query voip-asia.brahmakumaris.org block 0
[0]->31.6.78.124:5060(910)
INVITE sip:004@voip-asia.brahmakumaris.org SIP/2.0
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-11d04ccf
From: "Brahma Kumari Canberra" <>>6010@voip-asia.brahmakumaris.org>;tag=b99a4fb8adee114eo0
To: <>>004@voip-asia.brahmakumaris.org>
Call-ID: d827b780-c0f68c26@192.168.1.41
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
User-Agent: Cisco/SPA112-1.0.2(006)
Content-Length: 331
Supported: replaces
v=0
o=- 109351 109351 IN IP4 192.168.1.41
s=-
t=0 0
m=audio 16392 RTP/AVP 2 18 0 8 100 101
a=rtpmap:2 G726-32/8000
a=rtpmap:18 G729a/8000
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<31.6.78.124:5060(549)
SIP/2.0 407 Proxy Authentication Required
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-11d04ccf;received=60.240.77.7
To: <>>004@voip-asia.brahmakumaris.org>;tag=as7d844705
CSeq: 101 INVITE
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="458c760d"
Content-Length: 0
[0]->31.6.78.124:5060(457)
ACK sip:004@voip-asia.brahmakumaris.org SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
[0]->31.6.78.124:5060(1089)
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-2f9add97
CSeq: 102 INVITE
Max-Forwards: 70
Proxy-Authorization: Digest username="6010",realm="asterisk",nonce="458c760d",uri="sip:004@voip-asia.brahmakumaris.org",algorithm=MD5,response="080626f0d87dbcd5b124b72491369bcb"
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<31.6.78.124:5060(471)
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-2f9add97;received=60.240.77.7
CSeq: 102 INVITE
Supported: replaces
Contact: <004>004>
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 102 INVITE
Supported: replaces
Contact: <004>004>
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 102 INVITE
Supported: replaces
Contact: <004>004>
Content-Length: 0
[0]<<31.6.78.124:5060(789)
SIP/2.0 183 Session Progress
To: <>>004@voip-asia.brahmakumaris.org>;tag=as54d5f390
CSeq: 102 INVITE
Supported: replaces
Contact: <004>004>
Content-Length: 260
v=0
s=session
t=0 0
m=audio 12518 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*** RTP channel not in Tx. Nothing to stop!
[AUD]RTP Tx Down
[AUD]AUD_startRtpTx(0x1ef7c0, 0, 31.6.78.124, 12518, 20)
cordless_start_rtp(), chan:0 remote ip:31.6.78.124 port:12518 local:16392 rx:0 ipt:0 ptime:20
Remote IP/port: 31.6.78.124:12518
RTP configuration:
[AUD]RTP Tx Up
cordless_start_rtcp(), chan:0 remote ip:31.6.78.124 port:12519 intvl:0
Socket 26 bound to RTCP port 16393.
[AUD]RTCP Up
CC_eventProc(), event: CC_EV_SIG_CALL_PROGRESS(0x35), lid: 0, par: 3, par2: (nil)
AUD_ccEventProc: event 53 vid 0 par 0x3 par2 0x0
callEventProcTable[3] is cepCallingProc
cepCallingProc(line=0x1c6528, call=0x1c652c, event=53(CC_EV_SIG_CALL_PROGRESS), par=3, par2=(nil))
CC:CallProgress
NEW_CALL_STATE(), call 0: old state = 3, new state 4
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
Going from Tx only to bi-directional.
RTP configuration:
Going from Tx to bi-dir just need updating.
RTP session 0 updated
[AUD]RTP Rx Up
[0]On Hook
callEventProcTable[4] is cepCallingProc
cepCallingProc(line=0x1c6528, call=0x1c652c, event=1(CC_EV_USR_ONHOOK), par=0, par2=(nil))
cepCallingProc(line=0x1c6528, call=0x1c652c, event=10(CC_EV_USR_ENDCALL), par=0, par2=(nil))
NEW_CALL_STATE(), call 0: old state = 4, new state 0
SLIC_stopRing
SLIC_stopTone
SIP_lineCcCmdProc(), cmd=CC_CMD_ENDCALL
RTP configuration:
rx[0] 0 G.726/8000, rx[1] 18 G.729/8000, rx[2] 0 PCMU/8000
[AUD]RTP Tx Down
RTP configuration:
[AUD]RTP Down
[0:0]AUD Rel Call
[0]->31.6.78.124:5060(563)
CANCEL sip:004@voip-asia.brahmakumaris.org SIP/2.0
CSeq: 102 CANCEL
Max-Forwards: 70
Proxy-Authorization: Digest username="6010",realm="asterisk",nonce="458c760d",uri="sip:004@voip-asia.brahmakumaris.org",algorithm=MD5,response="9e73603bd3ec65e6abc330572f446d0d"
Content-Length: 0
Set QoS succeed
CSeq: 102 CANCEL
Max-Forwards: 70
Content-Length: 0
CSeq: 102 CANCEL
Max-Forwards: 70
Content-Length: 0
[0]<<31.6.78.124:5060(460)
SIP/2.0 487 Request Terminated
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
[0]->31.6.78.124:5060(636)
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
[0]<<31.6.78.124:5060(476)
SIP/2.0 200 OK
CSeq: 102 CANCEL
Supported: replaces
Contact: <004>004>
Content-Length: 0
DLG Terminated 255b38
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 CANCEL
Supported: replaces
Contact: <004>004>
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 CANCEL
Supported: replaces
Contact: <004>004>
Content-Length: 0
[0]Off Hook
SLIC_stopRing
SLIC_startTone 1
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Set QoS succeed
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
line:0 DTMFON event received digit 6
EVQ_read: 1 6 in 2024092
EVENT_DTMFON 6
CC_eventProc(), event: CC_EV_USR_DTMFON(0x4), lid: 0, par: 54, par2: (nil)
AUD_ccEventProc: event 4 vid 0 par 0x36 par2 0x0
line:0 DTMFOFF event received digit 6
EVQ_read: 0 6 in 2024092
EVENT_OOB_DTMF 6
CC_eventProc(), event: CC_EV_USR_OOB_DTMF(0x8), lid: 0, par: 54, par2: 0x64
AUD_ccEventProc: event 8 vid 0 par 0x36 par2 0x64
cepDialingProc(line=0x1c6528, call=0x1c652c, event=8(CC_EV_USR_OOB_DTMF), par=54, par2=0x64)
cepIdleProc(line=0x1c6528, call=0x1c6734, event=8(CC_EV_USR_OOB_DTMF), par=54, par2=0x64)
SLIC_stopRing
SLIC_startTone 1
EVENT_DTMFOFF 6
CC_eventProc(), event: CC_EV_USR_DTMFOFF(0x5), lid: 0, par: 54, par2: (nil)
AUD_ccEventProc: event 5 vid 0 par 0x36 par2 0x0
cepDialingProc(line=0x1c6528, call=0x1c652c, event=5(CC_EV_USR_DTMFOFF), par=54, par2=(nil))
cepDialingProc(), digit = 6
cepIdleProc(line=0x1c6528, call=0x1c6734, event=5(CC_EV_USR_DTMFOFF), par=54, par2=(nil))
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
EVENT_DTMFON 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
EVENT_OOB_DTMF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFOFF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFON 0
EVENT_OOB_DTMF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFOFF 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFON 4
EVENT_OOB_DTMF 4
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
EVENT_DTMFOFF 4
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Sess Terminated
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
cepDialingProc(), dn = 6004
pconly: 0
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
Calling:6004@voip-asia.brahmakumaris.org:0, rc=0
RTP_nextMediaPort(), port = 16396
RTP_nextMediaPort(), rc=16394
[0:0]AUD ALLOC CALL (port=16394)
cordless_start_rtp(), chan:0 remote ip:(null) port:0 local:16394 rx:1 ipt:0 ptime:0
Socket 19 bound to port 16394.
RTP configuration:
[AUD]RTP Rx Up
[0]->31.6.78.124:5060(912)
INVITE sip:6004@voip-asia.brahmakumaris.org SIP/2.0
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-673577dc
From: "Brahma Kumari Canberra" <>>6010@voip-asia.brahmakumaris.org>;tag=44eeabaf843d1557o0
To: <>>6004@voip-asia.brahmakumaris.org>
Call-ID: e5184c8f-2f44e9f7@192.168.1.41
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
o=- 111291 111291 IN IP4 192.168.1.41
s=-
t=0 0
m=audio 16394 RTP/AVP 2 18 0 8 100 101
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 101 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<31.6.78.124:5060(550)
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-673577dc;received=60.240.77.7
To: <>>6004@voip-asia.brahmakumaris.org>;tag=as59c2760b
CSeq: 101 INVITE
Supported: replaces
Proxy-Authenticate: Digest algorithm=MD5, realm="asterisk", nonce="788423f6"
Content-Length: 0
[0]->31.6.78.124:5060(459)
ACK sip:6004@voip-asia.brahmakumaris.org SIP/2.0
CSeq: 101 ACK
Max-Forwards: 70
Content-Length: 0
[0]->31.6.78.124:5060(1092)
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-d1393f2c
CSeq: 102 INVITE
Max-Forwards: 70
Proxy-Authorization: Digest username="6010",realm="asterisk",nonce="788423f6",uri="sip:6004@voip-asia.brahmakumaris.org",algorithm=MD5,response="fb1586d4a4a7ed65cf94223ce19135e0"
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
CSeq: 102 INVITE
Max-Forwards: 70
Expires: 240
Content-Length: 331
Supported: replaces
v=0
s=-
t=0 0
a=fmtp:100 192-193
a=fmtp:101 0-15
a=ptime:30
a=sendrecv
[0]<<31.6.78.124:5060(473)
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-d1393f2c;received=60.240.77.7
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
SIP/2.0 100 Trying
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
[0]<<31.6.78.124:5060(489)
SIP/2.0 180 Ringing
To: <>>6004@voip-asia.brahmakumaris.org>;tag=as1d28e1a6
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CC_eventProc(), event: CC_EV_SIG_CALL_RINGING(0x33), lid: 0, par: 4, par2: (nil)
AUD_ccEventProc: event 51 vid 0 par 0x4 par2 0x0
cepCallingProc(line=0x1c6528, call=0x1c652c, event=51(CC_EV_SIG_CALL_RINGING), par=4, par2=(nil))
CC:Ringback
RTP configuration:
[AUD]RTP Down
SLIC_stopRing
SLIC_startTone 9
SIP/2.0 100 Trying
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
CSeq: 102 INVITE
Supported: replaces
Content-Length: 0
[0]<<31.6.78.124:5060(777)
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
m=audio 19950 RTP/AVP 0 8 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
SIP_sessDlgEventProc: event: 41, ucState: 2
[AUD]RTP Down
[AUD]AUD_startRtpTx(0x1ef7c0, 0, 31.6.78.124, 19950, 20)
cordless_start_rtp(), chan:0 remote ip:31.6.78.124 port:19950 local:16394 rx:0 ipt:0 ptime:20
Starting Tx only RTP.
Remote IP/port: 31.6.78.124:19950
RTP configuration:
audio_mode RTP_MODE_SEND_ONLY, media_loop_level RTP_LOOP_LEVEL_NONE, dtmf2833numEndPakcets 3, opts 0x0
[AUD]RTP Tx Up
cordless_start_rtcp(), chan:0 remote ip:31.6.78.124 port:19951 intvl:0
Socket 26 bound to RTCP port 16395.
[AUD]RTCP Up
CC_eventProc(), event: CC_EV_SIG_CALL_RESUMED(0x2C), lid: 0, par: 4, par2: (nil)
AUD_ccEventProc: event 44 vid 0 par 0x4 par2 0x0
cepCallingProc(line=0x1c6528, call=0x1c652c, event=44(CC_EV_SIG_CALL_RESUMED), par=4, par2=(nil))
CC:Remote Resume
SLIC_stopRing
SLIC_startTone 9
*** RTCP already running on channel 0.
CC_eventProc(), event: CC_EV_SIG_CALL_CONNECTED(0x2A), lid: 0, par: 4, par2: (nil)
AUD_ccEventProc: event 42 vid 0 par 0x4 par2 0x0
cepCallingProc(line=0x1c6528, call=0x1c652c, event=42(CC_EV_SIG_CALL_CONNECTED), par=4, par2=(nil))
CC:Connected
NEW_CALL_STATE(), call 0: old state = 4, new state 8
SLIC_stopRing
SLIC_stopRing
SLIC_stopTone
RTP configuration:
[AUD]RTP Rx Up
[0]->192.168.1.41:5060(629)
ACK sip:6004@192.168.1.41:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-2784d1ee
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
[0]<<192.168.1.41:5060(629)
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
RespLooseMatch
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
RespLooseMatch
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
RespLooseMatch
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK1c8d78b5;rport
To: <6010>6010>
Contact:
Call-ID: 5f5826d369fa73b279355c2e41d4c72b@31.6.78.124
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:31:36 GMT
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length: 0
Supported: replaces
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
SIP/2.0 200 OK
CSeq: 102 INVITE
Supported: replaces
Content-Length: 260
v=0
s=session
t=0 0
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
*** ICMP error on RTP ch 0. Err count 1.
*** ICMP error on RTP ch 0. Err count 2.
*** ICMP error on RTP ch 0. Err count 3.
*** ICMP error on RTP ch 0. Err count 4.
*** ICMP error on RTP ch 0. Err count 5.
*** ICMP error on RTP ch 0. Err count 6.
*** ICMP error on RTP ch 0. Err count 7.
*** ICMP error on RTP ch 0. Err count 8.
*** ICMP error on RTP ch 0. Err count 9.
*** ICMP error on RTP ch 0. Err count 10.
*** ICMP error on RTP ch 0. Err count 11.
*** ICMP error on RTP ch 0. Err count 12.
*** ICMP error on RTP ch 0. Err count 13.
[0]On Hook
cepConnectedProc(line=0x1c6528, call=0x1c652c, event=1(CC_EV_USR_ONHOOK), par=0, par2=(nil))
cepConnectedProc(line=0x1c6528, call=0x1c652c, event=10(CC_EV_USR_ENDCALL), par=0, par2=(nil))
NEW_CALL_STATE(), call 0: old state = 8, new state 0
SLIC_stopRing
SLIC_stopTone
RTP configuration:
[AUD]RTP Tx Down
RTP configuration:
[AUD]RTP Down
[0:0]AUD Rel Call
[0]->192.168.1.41:5060(555)
BYE sip:6004@192.168.1.41:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.41:5060;branch=z9hG4bK-f26798e4
CSeq: 103 BYE
Max-Forwards: 70
Proxy-Authorization: Digest username="6010",realm="asterisk",nonce="788423f6",uri="sip:6004@192.168.1.41:5060",algorithm=MD5,response="3032cd0f4995c977c8d02f48a7d6c00a"
Content-Length: 0
[0]<<192.168.1.41:5060(555)
CSeq: 103 BYE
Max-Forwards: 70
Content-Length: 0
[0]->192.168.1.41:5060(346)
SIP/2.0 404 Not Found
CSeq: 103 BYE
Content-Length: 0
[0]<<192.168.1.41:5060(346)
CSeq: 103 BYE
Content-Length: 0
DLG Terminated 255bcc
Sess Terminated
Set QoS succeed
CC:Clean Up
OP:SIPAUS = 4 ( 8 680) OP:SIPDLG = 10 ( 10 148)
Via: SIP/2.0/UDP 31.6.78.124:5060;branch=z9hG4bK1c2ef5d4;rport
To: <6010>6010>
Contact:
Call-ID: 45339d596190c5df78a4b73336123854@31.6.78.124
CSeq: 102 OPTIONS
Max-Forwards: 70
Date: Tue, 16 Apr 2013 01:32:36 GMT
Supported: replaces
Content-Length: 0
SIP/2.0 200 OK
CSeq: 102 OPTIONS
Content-Length: 0
Supported: replaces
04-16-2013 01:04 AM
The LOG you attached seems to catch at least three calls. You didn't mentioned if you have problem with incomming calls, outgoing calls, both direction calls.
The first call has been incomming call from 6004 to 6010. This call has been terminated from Asterisk's side.
The second call has been outgoing call from 6010 to 004 (not 6004!). It reached the PROGRESS state (I assume you heared the message "called number doesn't exist" or so) and has been terminated by on-hook event from the caller's side.
The third call from 6010 to 6014 reached the ringing state then has been terminated from Asterisk's side. It never reached connected state.
I assume the call [2] has been unintentional. Both calls 1 and 3 have been terminated from Asterisk's side. So check Asterisk's console (with raised debug and verbose level) for the reason.
04-16-2013 03:36 AM
Gday Dan,
Thanks for the swift reply. To answer your first question, the issue occurs in both directions. Be it incoming or outgoing calls, the line gets disconnected in a short time.
Yes, the 2nd call was unintentional Sorry, wasn't sure where to start deleting the longs and where to stop..so I decided to just paste the whole log for your review.
Thank you for the assistance so far. I will inform my Asterisk Admin to look into it. At least I can be clear that there's nothing wrong with my config or the device..
04-17-2013 01:53 AM
Ok. Then, the relevant parts from your log.
Call 1 (incomming call):
<- INVITE sip:6010@192.168.1.41:5060 SIP/2.0
To: <6010>6010>
-> SIP/2.0 100 Trying
-> SIP/2.0 180 Ringing
-> SIP/2.0 200 OK
<- ACK sip:6010@60.240.77.7:5060 SIP/2.0
<- BYE sip:6010@60.240.77.7:5060 SIP/2.0
The call has been established, then terminated from Asterisk's side.
Call 3 (outgoing call):
-> INVITE sip:6004@voip-asia.brahmakumaris.org SIP/2.0
From: "Brahma Kumari Canberra" <>6010@voip-asia.brahmakumaris.org>;tag=44eeabaf843d1557o0>
To: <>6004@voip-asia.brahmakumaris.org>>
Proxy-Authorization: Digest username="6010",...
<- SIP/2.0 100 Trying
<- SIP/2.0 180 Ringing
<- SIP/2.0 200 OK
<- SIP/2.0 200 OK
To: <>6004@voip-asia.brahmakumaris.org>;tag=as1d28e1a6>
s=session
t=0 0
[0]On Hook
The "ICMP error" message may reveal that there is an network problem between your device and PBX.
RTP (=audio here) packets seems doesn't pass to Asterisk. It may be either NAT problem or firewall problem.
04-19-2013 03:58 PM
Hi Dan,
Looking at your post..got me thinking. Had it been a NAT/FW problem, it wouldn't even allow me to establish a connection, would it? Like I mentioned earlier, I was able to establish the connection, have a conversation and bout 30secs later, it gets disconnected..To my understanding, the connection was established, but something happens as the call is in progress and the line gets disconnected.
Could it be the asterisk server has denied ping? Hence the ICMP error?
04-19-2013 11:29 PM
Althougth I'm big fan of thinking ;-), it can't replace the observation. I mean that packet dump is far-far better as the source for problem analysis that just founded hypothesis.
NAT and/or firewall rules can be created dynamically and dropped later. So NAT and/or firewall may be source of problem, even in the case "it worked, then become broken". Of course, it may not be source problem. It's packet dump that's help us to confirm or reject the hypothesis. In advance, the packet dump will help us to create more appropriate hypothesis that the one founded by just thinking.
The syslog/debug log revealed that there is a problem with delivery of RTP (e.g. audio, no SIP signalling packets including 'ping') packets. Undeliverable RTP packets may be reason for call disconnection. So we need to found possible network problem that may or may not be reason for disconnection after the timeout. "It is reason of disconnection and NAT or FW caused underlying network problem" is obvious first idea. Now we need to confirm it or found a better one.
By the way, the RTP problem may affect the one direction only. Did you verified you have two way working audio during the first 30s period ?
08-06-2021 10:58 PM
Try turning on NAT Keep alive, Under Voice>>>>Line 1>>> Nat Keep Alive Enable YES, this fixed the problem for us
