11-07-2012 08:55 AM - edited 03-21-2019 09:54 AM
I have tested and verified my provisioning server is sending my SPA122 all of the specific value's that I want implemented on my lab unit. When we deployed a unit into production, using the same provisioning server it's missing a bunch of specific XML that I need implemented.
The only difference that I can find between the 2 units is the "Boot Version" the date is different but the version number is the same....Why is the date different and would that have any affect on provisioning if there's a difference in the code?
Production
Boot Version: 1.0.1 (Oct 6 2011 - 20:04:00)
Lab
Boot Version: 1.0.1 (July 8 2011 - 15:33:57)
11-07-2012 09:31 AM
Hi George,
The date will not affect what you're describing.
What specific XML is missing on your production unit?
Look carefully at the config file:
Patrick
11-07-2012 01:50 PM
Hi Patrick. I didn't expect the date itself to be the issue but possibly if the Boot version was a different build than the one all of my testing was done with that maybe it would explain my issue.
My provisioning server generates the voice config (does nothing to router config). My issue is with the "router-config." I'm a little confused as to why this works fine on my one unit and is missed by the others (9 so far). (The configs are identical with the exception of the TNs and SIP passwords). All running Fw v1.2.1-004.
The entire
Everything before
Within
admin user
admin pass
guest user
guest pass
DNS server order
snmp (everything)
time zone
time server
and everything after works.
Here's the XML I'm using.
Thanks for your help.
11-09-2012 08:16 AM
Patrick,
Is there any debug I can enable that may explain why only some parameters aren't getting added during the re-sync? (I know my syntax is correct and actually we've proivsioned 15 units and none of them get the full config that my unit gets, a few got some more parameters than others.)
