SPA122 configuration to setup a Hotline
Selam
Trying to setup a SPA122 to be a Hotline. We will have a Hotline phone(no key pad) connected to line 1 and when the handset is picked up it should auto-dial a set number. Can't seem to find the options on the setup for doing this. Has anyone had a similar setup to this?
The "hotline", where you pickup the phone and it automatically dials a predetermined number, is done with the SPA122's dial plan. You change the default dial plan to a special one the accomplishes your requirement.
They are described in the SPA100 Series Phone Adapters Administration Guide.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/csbpvga/spa100-200/admin_guide_SPA100/spa100_ag_1_3_5.pdf
See page 145
The Admin Guide suggests
[code]
(P0<:1000>)
[/code]
where the example is dialing 1000
Thank you, Was able to get it working using this.
