We have separate admin and user password on our SPA525G2'sOur users are complaining that they keep having to login to the phone to see the restricted content. Is there an automatic logout timeout that can be adjusted ?
We have Cisco SPA302DKIT-G7.SPA232d has firmware 1.3.0 (019_240)I try update to latest version but firmware progress goes to 98% and stuck on it. I try to update with 1.3.5 and 1.3.2_014m_250_061913_1420 but still stuck on any update file.Does anyone...
I have configured a SPA504G (FW 7.5.4) with an Asterisk 1.8.20.1 to use TLS/SRTP. Overall it runs w/o any issues. The only problem I have is that when I in an encrypted call, another incoming call is only signalized on the display and the red light o...
Hello Readers,UC520 with Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 12.4(11)XW7, RELEASE SOFTWARE (fc2)Problem is in redirecting calls.We have telephone plan 271 001 2xx = 99 phone lines Our telephone xxx xxx 224 is for hot...
Hello, I am trying to change the user display name on my CISCO IP PHONE 303. Can you please provide instructions on this?
Also, on another phone someone accidentally did a full reboot of the phone and now there doesn't seem to be a connection to th...
i need help, i created a sip trunk with other sip server, but the cme give this error: 070846: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:Received:INVITE sip:900@200.111.156.150 SIP/2.0Via: SIP/2.0/UDP 54.207.30.33:5080;rport;branch=z9hG4bKD7U28atZZ6r...
Somebody hacked my SP112 and I was advised to chenge WAN access to desable. I did that and now I am unable to access it. I tried to use a phone to change the remote access parameter (action 7932#) but after entering # I get a message "invalid option"...
I have a customer with a Cisco 504g that the PC port periodically stops working. Usually rebooting the phone fixes the issue, but today it doesn't seem to be the case. The phone is running Software Version: 7.5.3. If he plugs his computer into any ot...
Hi all;I have a client with a UC540 where voice-mail functions have failed. The unit will not answer incoming calls although all parameters are configured and were working until this fault. CUE diagnostics run successful but you cannot access anythin...
Hi!I have set up SPA525g2 phone connection through VPN to my FreeSwitch. I can make first outbound call to any extension and it is ok, but second outbound call can't be done. I saw in FreeSwitch log that the during first call phone offering PCMA code...
Hi All,My company is using Vonage online PBX with Cisco SPA 303 IP phones, purchased direct from CDW and provisioned accordingly via Vonage provisioning instructions and tools. The issue I'm having is that from time to time, user phones show all oran...
Hello, i need to configure a SPA 3102 to use in associating with a Fritz!Box to make and receive call on a PSTN line. I have a 2nd line that i need to connect with Fritz!Box. What is the correct configuration of the spa 3102 to do so?Thank you
Guys, I have a client with a UC500. Seems it ALWAYS loses its credentials when the power is lost, doesn't matter how many times i save it. I've tried changing it in CCA, and in the CUE webgui, i'm starting ti yank my hair out because my client is get...
I have an SPA122 I'm having issues with running the 1.3.5 firmware. If I reset the device and configure only the items in the Simple Setup section, the phone will make and receive calls but there is a long delay between dialing the number and ringba...
