07-25-2018 03:23 AM
What is the Best practice to register SPA122 device with call manager? In proxy server which node ip need to be preferred ?
07-25-2018 04:26 AM
SPA122 can be connected as third-party/generic SIP device only (as far as I know). It needs to be connected to IP of the node offering SIP services.
See also: How to add linksys pap2t to ccm 7.1
07-25-2018 04:51 AM
07-25-2018 05:09 AM
I'm not familiar enough with call manager behavior. Unless someone else will advise you better, you can just try which node is willing to accept/deliver calls from/to SPA122.
10-16-2018 09:39 AM
Use the ip of whichever CUCM server you prefer it to register to. Alternately, use a domain name in that field and create SRV records in that domain which point to your call manager servers with your chosen priority/weight configuration. This allows the device to fail to a different call manager if the first one goes down.
You make an SRV record in dns in the zone you entered as proxy in your SPA (voip.domain.com, for example) and then the SRV record would be like _sip._udp.voip.domain.com with your SIP port (5060 usually), and a priority and weight for each call manager server based on the order you want the device to try to register to them. Lower number is higher priority, think of weight as load balancing within servers with the same priority number. Easiest if you have three CUCM and you want the device to register to them in one specific order, top down, is to set them as priority 1,2, and 3 and weight 100 for all.
On the spa you would have to set use dns srv to yes and the auto prefix based on if you're using the default (_sip._udp.) and whether you manually included it in your proxy address or just left it as voip.domain.com or domain.com or whichever domain you created your SRV records in.
