07-13-2016 11:28 AM - edited 03-21-2019 10:34 AM
I am new to the SPA122, and have one problem. If a call is active, and the caller hangs up, I don't get a tone like I would expect, it just hangs up, and plays the dial tone again.
I would expect a tone like -tut-tut-tut-tut- which only stops, if I hang up the call also.
I can't find a tone in the regional settings, where I can change this.
Do you have any ideas?
Manuel
Solved! Go to Solution.
07-13-2016 12:05 PM
It seems you have CPC configured, but phone doesn't honor such signal.
The SPA122 configuration must match the feature set supported by phone.
Disable CPC (set CPC Duration to zero) and try again.
07-13-2016 12:05 PM
07-13-2016 12:27 PM
Thank you very much!
That's it, not it works fine!
