04-04-2016 11:43 AM - edited 03-21-2019 10:32 AM
my name is Stefano and I have a problem with Spa232d
My spa232d with 1.4.1 firmware, after about 15-20 days of work, does not work with LAN locked and can only hard reset
My SPA232D Configuration ----> in LAN PBX Asterisk with 16 interior.
The fxs spa232d is recorded in the Asterisk PBX
After the block I can not see the logs files because I have to reset it
Possible is a Bug?
Help
Grazie
04-04-2016 12:01 PM
Of course, it is possible you hit bug. No way to confirm or reject with no informations available.
Is such device reachable from Internet ? Have you syslog&debug messages recorded ?
04-04-2016 12:16 PM
No device is not accessible from Internet
I have no error log
When you block have no way to see the log because I have to compulsorily reset
I am going crazy
04-04-2016 12:40 PM
Device save no valuable log itself even with no issue/reset. You need external syslog server running & SPA configured to send messages to it.
04-04-2016 01:16 PM
excellent
I can configure the device by sending logs to email?
04-04-2016 01:18 PM
No, classic syslog protocol is supported only.
04-04-2016 01:22 PM
Thanks so much
I try and test
You can recommend a software for the syslog server?
04-04-2016 01:27 PM
Most operating systems have a syslog server in default system installation. Such server is enough for the purpose in question.
I have no experience with Windows which is the only system with no syslog server as far as I know.
04-04-2016 01:30 PM
thank you so much
I try
04-07-2016 09:50 AM
04-07-2016 11:03 AM
So brief. It contain records with 'error' severity and above only.
Turn on highest debug level (e.g. 3) on SPA232D.
Configure your syslog server to record all messages (e.g. from 'debug' severity above).
