06-05-2013 05:29 PM - edited 03-21-2019 10:04 AM
My SPA203D currently is on firmware 1.2.0. When I go onto the web gui firmwar eupdate site the "browse" button is greyed out. Clicking F5 for site refresh shows the button clickable for a brief moment but one has to be quick to click it. I select the file but then the "Upgrade" button is not clickable either. Is this a bug?
This is the file I am trying: Firmware for SPA232D SPA302D, Version 1.3.2-014
Solved! Go to Solution.
06-06-2013 08:28 AM
Hi Stefan,
It could be that you're connected to the WAN port and have not authorized upgrades via the WAN port. Connect to the LAN port and try again.
It could be a browser issue, but I doubt it. Try with IE. I recall an issue with the SPA1xx on their early firmware where only IE was able to browse for a firmware file.
This document may help you: https://supportforums.cisco.com/docs/DOC-27890
Patrick---
06-06-2013 08:28 AM
Hi Stefan,
Patrick---
06-06-2013 09:32 AM
Thanks Patrick. Now, is there a ssh/telnet login available to edit the conf files?
06-06-2013 10:28 AM
Stefan,
No ssh/telnet access is available on this device. The way to change the configuration is to either:
https://supportforums.cisco.com/docs/DOC-28766
Patrick---
