spa3102 & CID
kabelnet2
I have configured my SPA3102 to handle CID on PSTN line. In our country the standard is ETSI FSK + V23. Everything is working fine - during a few calls or on first day. After that the 'Private caller' string is displayed on the phone, no caller id displayed on WEB information screen. If I switch off and on the device (SPA3102), the CID is displayed again during a few calls.
I use the latest firmware (5.1.10).
I hope, someone can help me.
Regards, kabelnet (Tamás Borlay)
96 Replies 96
Hi Anthony,
I'm checking with the team and will get back to you with an ETA for a fix.
Patrick
Thanks Patrick
That would be great.  Was trolling the net last night and have found a bunch of people on other forums reporting the same issue.  Some said they solved it but weren't specific how.
Looking forward to it.
Anthony
Hi Patric,
I am having a comparable proble, please keep me posted of the availability of a fix.
I am living in Ontario, Canada, and my service provider is Bell. The symptoms I have are the following
1- PSTN call received
2- Phone rings, CID is displayed
3- If the phone is not answered after the 2nd ring (Same call), the CID switches to "Private Name, Private Number"
I am running firmware version "5.1.10(GW)" on my SPA-3102 with H/W version "1.4.5(a)".
Other phones in the house work just fine. The SPA does not have a record of the "Last PSTN Caller"
Marwan
Just to let you know that I am still making contact with the development team in order to get an ETA on a fix.
Patrick
Hi Patrick,
Any update on when we can expect a fix?
Peter J
Hi Peter,
Apologies for the delayed response. I'm checking with product management and will report back shortly.
Patrick
Community update:
Product management reports that, "Our Engineering Team has identified and logged this issue into our tracking system and will schedule the necessary development and testing time to resolve and post a maintenance release for the SPA3102 firmware as soon as possible."
Patrick
Thanks Patrick.
Is there a TAC case number or bug id we can track?
Also, for my issue, the problems got so bad that all incomming calls stopped, not just the CLID. I logged a fault with my telco and they found a fault with the wiring (a joint was badly corroded). Once that was fixed, calls and CLID to the ATA are working as they should.
Cheers,
PDJ
Hi Peter & Community,
Per product management, I've assigned both this CID and the CID issue defined at https://www.myciscocommunity.com/message/13740#13740to CDETS# CSCtb67946
Engineering will now schedule a fix for this.
Next steps [very loosely described by me]:
1. Engineering management assigns task to Engineer
2. After analysis, a schedule is defined
3. Test code is produced
4. Code is tested by customer/s to verify fix
5. Code is tested, including regression testing
6. Schedule for general availability is defined
Patrick
Hi Patrick,
Do you have plan.
But what about the implementation?
(Please remember: 29/05/2009: "Cisco team have been able to replicate the issue in our labs", 13/07/2009: "will get back to you with an ETA for a fix", 31/08/2009: "the plan", and no any result until today)
Regards, Tamás
Hi Tamás,
Thanks for checking. I've have accessed the CDETS and have added a note to notify Engineering that a status has been requested.
Patrick
Patrick,
Two weeks have gone again.
Tamás
marwan-an wrote:
Hi Patric,
Marwan
I have this very same problem with very same hardware and very same firmware.
Any solution to this? Any ETA for a fixed firmware?
Hi Community,
I've contacted the product manager and requested a status on a fix.
Patrick
two months... any news? a beta version we can try? something?
