Hi guys,
This is my first post.
Here's my problem.
Back in the faaaar 2009, i bought a linksys PAP2 voip adapter. I used it for a few months and then i stopped using it.
Now after 8 years, i gave it to a friend, but we are stuck as i cant rem...
Hi Guys,
We have a Cisco UC560 has configured while ago by an engineer, and have left nothing about the settings.
The box have never had a backup before, which I now want a current working config backup therefore I can more confidently make change ...
I'm troubleshooting a non-working caller-id between spa112 and telos hx6 (this is google'able). while checking whatever possible, I tapped into the phone line and got the attached graph (a lot more of actual data available upon request, the whole ses...
one of my SIP-Providers uses the country code for the incomming caller id formated "+49 xxxx xxxxx". On the Display of the SPA-302D it is shown as 49 xxxx xxxxx. This does several issues to me. The CID isn't mapped to a known contact, which is ...
I have an home-made HTTPS-only provisioning server using a certificate generated by Cisco CA.
Since I have upgraded my test phone to firmware version 7.6.2, the HTTPS provisioning is no longer working. The provisioning server log does not log an...
I have a customer on a very old release of Call Manager 7.2 and no maintenance. We are looking to purchase maintenance to get things up to date. What is the appropriate path for adding maintenance - can i add a current 1 year subscription to get the ...
I am provisioning an SPA112 firmware version 1.4.1 for Broadsoft. I change the admin and guest password in the config file. When the SPA112 recovers I am still able to use the default login. Below are my changes. Any assistance would be greatly appre...
I can not understand how I can enter the dial plan the character #
my dial plan is this:
(* Xx | [3469] 11 | 0 | 00 | [2-9] xxxxxx | 1xxx [2-9] xxxxxxS0 | xxxxxxxxxxxx.)
if you call the number *67#3451245123
pbx comes on
*67%23451245123
How c...
Hello. We have several SPA504G phones. Same network without NAT, same PBX. Some units accept simultaneous calls to all four extensions and reply with four "Ringing" messages. Other SPA units accept only one call to any ext and reject more that one ca...
Hi,I have several SPA8000 & SPA112 ATA's, and I know it's possible to make analog phones set their system date+time via SIP INFO header or so, but have no idea how to do it or which configuration do I need.Does anyone done this ever/have this configu...
This unit has been working fine for about 3 years at least. Occasional drops that need a reboot. However, yesterday is has gone down hard and will not register. Logs show:
Mar 26 16:25:07 SPA122 kern.err [17179569.424000] physmap-flash physmap-flash....
Do Cisco phones (in my case SPA504G) support only 'monaural' (mono) headsets?
Just because I've tried my 2.5 Nokia headset, which is stereo, and either of the earpiece and the microphone wouldn't work.
However the headset works well with Noki...
This must be an easy question for those who know the answer.
It is about Cisco SPA504GCan I disable certain lines, extensions with the phone itself without accessing the web interface?
If yes; where can I set it?
I haven't played around with i...
How to use SNMPv3 commands with SPA122 ATA ?
SNMPv3 support is enabled in SNMP management settings.
Did not find any examples of SNMPv3 commands for SPA122.
I down graded my firmware to fix a dialing issue, now can't get to web configuration screen to completely load. I did a factory reset, but that does not fix it. Just cause me to loose my phone settings and auto attendant settings....
Does anyone kno...
