01-21-2011 03:32 PM - edited 03-21-2019 09:32 AM
Telephony is fine but my download speed is cut to 7+Mb with the 3102 connected. Is this an inherent limitation or can I find settings that allow higher speeds. My connection is 20Mb without the ATA.
01-22-2011 12:15 PM
Do you have set the QoS in WAN configuration?
If yes, try to disable it setting QoS QDisc to NONE.
Do you have loaded the latest firmware?
Regards.
01-22-2011 02:23 PM
Thanks for the reply. The firmware is 5.1.10 and I tried QoS Qdisk in both settings, None and ?TBK, with the same result.
