SPA3102 Parse error
Michel-DUPUY
I have some troubles with my SPA3102.
I use debug level 3 and after a reboot I have the following messages:
<134>System started: ip@192.168.0.3, reboot reason:H0
<143>.subnet mask:.255.255.255.0
<143>.gateway ip:.192.168.0.1
<143>.dns servers(1):
<143>192.168.0.1
<143>
<159>IDBG: st-0
<134>YM:ERR:AuthServerNotConfig
<134>[0]Reg Addr Change(0) 0:0->5b798111:5060
<151>TP Parser error: 9
<159>[0]RegOK. NextRegin 3570 (1)
<159>fs:11725:11725:65536
<159>fls:af:1:0:0
<159>fbr:1:3000:3000:14f19:0004:0005:5.1.10(GW)
<159>fhs:01:0:0001:upg:app:0:3.3.6(GW)
<159>fhs:02:0:0002:upg:app:1:3.3.6(GW)
<159>fhs:03:0:0003:upg:app:2:3.3.6(GW)
<159>fhs:04:0:0004:upg:app:0:5.1.10(GW)
<159>fhs:05:0:0005:upg:app:1:5.1.10(GW)
<159>fhs:06:0:0006:upg:app:2:5.1.10(GW)
<159>fu:1:4f2b, 0003 0001
<159>[0]Off Hook
<151>2. Report digit # (1)(40 ms)
<151>[0]PlayOutDial 1
<159>[0]On Hook
Where I can find an explanation of the debug messages?
How to find the error on my configuration file?
Many thanks in advance,
Michel
customata
"TP Parser error" is an error message reported by the SIP header parser. It has nothing to do with your configuration file. If it happens in connection with registering to your provider, it's likely that your provider is returning a response with incorrect syntax. The error code returned in your case, ie '9', usually means that it's getting a URI (the part within angle brackets in the headers To, From, Contact, etc) that doesn't start with a method, eg "sip:", or that specifies a method that exceeds the buffer space available to store it. You need to capture/log the SIP messages received from your provider and examine them for correctness.
