SPA3102 Simple Configuration Help
davila_eric
Hi All,
I am a total newbie looking for the easy button.
I would like some screen shots or pointers on configuring my SPA3102.
I have a simple set up, one POTS line and a SIP account with Skype.
I want to configure my SPA3102 to take all incoming PSTN calls (so I don't have to change my phone number or use up my bandwidth all the time).
I want all out going local calls (303 and 720 area code) and possibly 911 (if possible) to go out the PSTN line, but all long distance to go to my SIP account on SKYPE.
Pretty simple, but I can't find an samples in the documentation or a wizard in the firmware configuration screen for the SPA3102.
Thanks in advance.
ADAM CRISP
Level 4
Level 4
Hi Eric,
You need to do some research on "dial-plans"
check out
http://homekb.cisco.com/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=5179
and googling "linksys spa dial plan"
You'll be configuring a gateway account, and then using the dial-plan to reference the gateway for your interesting dialed digits.
Adam
