SPA500S + SPA504G + SPA9000 shared line appearance
adminitsro
I  have working setup with one SPA500S attendant console attached to  SPA504G phone. Now I need attach second set of SPA504G+SPA500S to  SPA9000 and it is not working.
The  problem is, that appearance leds on SPA500S are flapping. Only one  SPA500S at a time has green leds, second has all leds orange. After some  time (~5 minutes) the leds in first SPA500S are getting orange and on  the second green.
Is this setup supported? Or have I some bug in configuration?
Thank you
Dan
nseto
Level 6
Level 6
If you are monitoring the same extensions on that 2nd sidecar as the 1st sidecar, this isn't supported with the spa9000.
