09-03-2013 11:55 AM - edited 03-21-2019 07:44 AM
I have a uc520.
Is it possible to configure buttons on a SPA504g and/or on 500S extension, to dial an external number?
Thank you in advance,
09-03-2013 02:04 PM
This can be done. The speed dial number has to be configured exactly the way it would be dialed from the phone.
If you are using CCA, open the phone, and there is a tab where you can define the speed dials.
-john
09-03-2013 02:43 PM
Hi John,
Thank you for your reply,
How can i define external numbers as speed dials to these buttons?
