SPA504G display calling name + language
Hello!
I have posted my question in IP Phones but didn't get any answer.
https://supportforums.cisco.com/thread/2076988
May anyone can help me here.
Thank you!
Daniel
David Trad
Hi Daniel,
I am helping another Forum user out on a similar problem, but have faced the same challenges as he has, so when I am able to overcome them or at least find a work around I will be post the update on this.
You can follow the thread HERE
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi David,
thank you for reply.
I will check your help in another forum.
Best Regards
Daniel
