So how do you get teh SSL VPN on a 525G to work when there is an SA520 in front of the UC540?
Hi guysi just install a UC540 with SPA525G2 phonei would like to know if with cca their any way to set aa only during closed hours and ring all phone during business hour without welcome messagei do something with night service by forwading it to voi...
UC560 has a PRI connection that has a main phone number (that is on all 23 B channels) that will need to ring down to our reception's extension, Can you share how to enable this?In the FXO world it is "connection plar 1000" - just want to know how ...
Is anyone else experiencing issues with the speaker on the SPA525G? I have a customer that is experiencing intermittant speaker issues whereby pressing the speaker button does not result in hearing anything, and when the phone rings, the line button...
I have set up businesshours as M-F 8:30 to 5:00 and eveninghours as M-F 5:00pm to 9:00pm. How do I Set a schedule variable MySchedule to one the schedules?Set property:Variable: MyScheduleAssign: ???
Hello everybodyi have question about WRP400 is there some chance how i can set up WRP400 to bridge mode, like SPA2102.Thank you Tomas
I tried with both my land line as well as my mobile phone and found that I did not have to check the ‘Allow External Transfer’ and was able to dial by number at any time. I am using your custom script ‘AA_SBCS_v03.aef’ per ‘TEL27a_Alt_Greeting+Dial_b...
Hello !Is there a way to integrate SPA301G into UC560 by using SPCP?UC560 is not "recognising" SPA301G phones , but they are "supported"?Is there a exact way to integrate this solution?Thanks for answers in advice.
Using CCA 2.2(5), I have been adding my extensions and caller ID numbers to override the default caller ID in my outgoing dial plan. Once I hit 14 extensions, I cannot add anymore. Is this a limit? Should I be doing it somewhere else?Thank you.
Hi,I configured the new SPA504G with the extension created asterisk server. It took awhile before the lines turned green. Is there a register to asterisk time interval that can be set to least on the 504G?
UC540Software PAck 8.1CCA 3.0I have tried this on two UC540's with the same resultsI want to dial out on fxo port 0/2 if 0/0 and 0/1 are being used.In outgoing dial plan I choose the sequential hunt scheme and vertically order the fxo ports with the ...
Sorry if this has been posted already or in a release note, I just have not found it yet. I have been looking into an issue with background images not showing up from my test phone with the 8.1 software pak. I see the pictures and xml files in the ...
Has anyone been able to figure out the setting that needs to change to allow a PC to connect to an external PPTP server from behind the UC500? I've had no luck in this and have allowed GRE passthrough and setup pptp inspect rules. Still no love.
Hello,I have UC 560, I need to change background image on my IP phone 7965, when i select the image from user preferences, background images i can see my current image on the phone, but the image which i copied through TFTP look like as a screen with...
Hey guys, Looking for a way to program one of my line keys to do a In-Call Call Record (*1)Have the key flash red (identifying that its Activated) and press again to show not recording.First is the function of actually doing an incall recordfnc=blf+s...
