05-07-2010 06:28 PM - edited 03-21-2019 02:32 AM
HI,
I have an SPA9000 and SPA400 connected with 10 SPA9xx, 1 WIP310 and 3 SPA504g, the problem I have it´s when an incoming PSTN call is
transfer from an SPA9xx phone to an SPA504g phone (any of the 3 phone I have), the SPA504g phone freeze, the only way to unfreeze the phone its disconnecting the phone.
This happend randomly, from 6 calls, 2 to 3 fails.
Pleae let me know how to fix the problem
Jerry
Hola,
Tengo un SPA9000 y un SPA400 conectados a varios SPA9xx y a 3 SPA504g, el problema que tengo es cuando entra una llamada PSTN,
esta llamada la recibe un SPA942, al transferir la llamada a cualquiera de los SPA504g, el telefono se congela y solamente desconectandolo
vuelve a la normalidad, esto sucede aleatoriamente, de 6 llamadas 2 a 3 fallan. Esto no sucede con los telefonos SPA9xx.
Mucho agradecere su ayuda.
Gracias,
Gerardo
05-13-2010 03:09 PM
Are the phones running the latest software? What happens when transfer from 50x to 90x phone?
Do you happen to have a log or trace of this?
05-14-2010 10:27 AM
The phones are running the following version:
7.1.3a
When I transfer from 50x to 90x, everything it's ok.
Attached a syslog trace, please let me know if you need something else.
192.168.2.193 ---> SPA9000
192.168.2.194 ---> SPA400
192.168.3.193 ---> SPA9000 remote office
192.168.1.193 ---> SPA9000 remote office
192.168.1.194 ---> SPA400 remote office
192.168.2.82 ---> SPA504g
Jerry
05-14-2010 11:02 AM
The 6 MB log contains a bunch of registration and notify messages, mostly with spa9000 and spa400.
Since you have remote offices, does this transfer problem occur with calls between offices and/or with calls within just the local office?
It would also help to upgrade your 50x to 7.4.4 located on cisco.com.
For the log, just turn it on in the 50x phone. Set the SIP debug option to full excl opt|ntfy|reg.
The slogsrv program has an option to put in timestamp, it's slogsrv -t, this would add timestamps and parse the syslog header. This way, you can tell me what time the issue occured and I can look for it in the log based on time.
