SPA504G SideCar Programming
colby
I'd like to program my SideCar to only be a location for Speed Dial numbers. What's the programming language that I need to be putting into my interface to be able to dial outside of my small business location.
I've discovered that putting nme:(insert name) will make it appear on the sidecar, but can't figure out what makes it actually call out.
Thanks in advance for your help!
Dan Lukes
You should start with basic product documentation - Administration Guide. especially Configuring Speed Dial - SPA500(D)S expansion modules are using same syntax.
