SPA504G SPA514G Default Character Encoding stay in ISO-8859-1
gauvenet67
I have configure like:
  <Dictionary_Server_Script ua="na">serv=http://{{ provisioning.server }}/telecom/language/;d0=English;x0=spa50x_30x_en_v754.xml;d1=French;x1=spa50x_30x_fr_v754.xml;</Dictionary_Server_Script>
  <Language_Selection ua="na">French</Language_Selection>
  <Default_Character_Encoding ua="na">UTF-8</Default_Character_Encoding>
  <Locale ua="na">fr-FR</Locale>
Dictionary and Provisioning Profile are encoded in UTF-8.
but when the phone start after provisioning the Default_Character_Encoding set to ISO-8859-1
and the lines labels are misprinted.
Ligne 1
Ligne 2
Olivier
Françoise
instead of
Ligne 1
Ligne 2
Olivier
Françoise
Any idea ?
nseto
Level 6
Level 6
I got an answer from the developer.
Pasted here.
I think the default encoding is set back to ISO8859 after customer download the dictionary.
Here is the reason: after 7.5.3, SPA 50x will parse the trkLocaleName in dictionary, for French it will set the phone’s default encoding to iso8859-1 since it is good to French.
French
  • •1.         If the customer want to use UTF-8 after xml downloading, please modify the trkLocaleName in the French dictionary xml as following:
croatian
It is a workaround, but it's strange why French user will use UTF8. Thanks.
  • •2.         Another way is that user can manually set the default encoding value to UTF-8 after xml downloading.
