SPA504g + VoiceView Vacation Greeting
warrenrees
I'm running into an odd problem with our UC560/SPA504g setup.
When attempting to change to the vacation greeting on the SPA504g phone via voiceview express, trying to set the "Enable Until Time", if I chose Indefintitely it works as expected.  If I attempt to "Set End Date", I can choose the Month, the Day, however when I attempt to set the Hour I get "404 not found" in the bottom status line of the phone.
If I use my CP7975, running through the same process it will let me select then hour, then minute and activate it like it should, so I don't believe it's a UC560 issue, but rather something with the SPA504g's.  I've got 2 UC560 systems and a UC540 system and all of them seem to exhibit the same behavior.
System Setup:
UC560 w/ Software Pack 8.2 installed
SPA504g w/ Firmware 7.4.8a
I haven't opened a ticket with support yet, but I'm curious if anyone else is running into this problem, and if so, what the solution might be?
Thanks!
Warren
0 Replies 0
