Excuse my english, I'm a french user. I will try to do my best
I search before on the forum, I haven't find any answers exactly to my problem.
I am having a problem trying to setup separate VLAN's for voice (vlan 2) and PC (vlan 3) on a 504G (firmware 7.4.9c) connected to a Cisco SGE2010p switch (firmware 3.0.0.18) in layer 3 mode (standalone), I use lcli. Also I'm with an asterisk server and SIP firmware.
I wish two vlans on my network :
vlan 2 (named Voix) : 192.168.6.0/24 (DHCP server is present)
vlan 3 (named Data) : 192.168.0.0/24 (DHCP server is present)
Basically with "switchport mode access vlan 2" and VLAN's turned off the phone receives its IP and configuration via DHCP without any problem.
Routing inter-vlan is working, provisionning and so on, it's OK without vlan support.
However whenever I setup the phone, with XML provisionning, as such it stops working :
Enable VLAN: Yes
VLAN ID: 2
CDP: No
LLDP : No
EnablePCPortVLANTag: Yes
PCPortVLANID: 3
The switch port that the phone is connected to, is a member of VLAN2 Untagged and VLAN3 Tagged.
(Switchport mode trunk)
Port Mode: Trunk
Gvrp Status: disabled
Ingress Filtering: true
Acceptable Frame Type: admitAll
Ingress UnTagged VLAN ( NATIVE ): 2
Port is member in:
Vlan Name Egress rule Port Membership Type
2 Voix Untagged Static
3 data Tagged Static
With this "mode trunk", the phone stops working as soon as vlan are enable, the ping is NOK.
I have try also with "mode general", with native vlan 2 and vlan 2&3 tagged but it does not work..
I do not use vlan 1 and, if it is possible, i don't want to.
I tried several combination with native vlan 2 or 1, with mode trunk or General...
And of course, I need it quickly for production environnement..
If you have any template to configure this type of architecture, or some advice to solve this problem..
Thank you,
