03-04-2013 02:49 PM - edited 03-21-2019 07:03 AM
I have a spa508 using 7.5.4. I am only able to get it to register 7 lines. If I add an 8th line one (at random) will not register. I have tried this using 8 different numbers, the same number 8 times, and a combination of the two. I am getting a sip 504 message on the one that does not register, however it never hits my server. I am registereing to a Metaswitch
Sage
03-18-2013 10:33 AM
So who is sending the 504 response to you if server doesn't participate in dialog ? You should catch the packet dump for further analysis.
03-28-2013 12:16 PM
It just work for me. See attached screenshot. All eigth lines are registered.
It's either Metaswitch's issue or you have NAT between the device and PBX and it's NAT issue. As I recomended, catch the packets.
