spa508 not applying config from $MAU config file
Sage Major
I have several 508's that are doing this
They read and apply the 508g.cfg config file from profile rule, but dont apply profile rule b.  After a reboot it will apply rule b.  Reboot again and it will apply only profile rule
<Profile_Rule group="Provisioning/Configuration_Profile">tftp://xxx/spa508G.cfg</Profile_Rule>
<Profile_Rule_B group="Provisioning/Configuration_Profile">tftp://xxx/spa/508/$MAU.xml</Profile_Rule_B>
Also I have the downgrade limit set but the firmware keeps trying download  to 7.5.2b, even though it has  7.5.4 applied
<Downgrade_Rev_Limit group="Provisioning/Firmware_Upgrade">7.5.3</Downgrade_Rev_Limit>,
<Upgrade_Rule group="Provisioning/Firmware_Upgrade">
tftp://xxxx/spa/firmware/50x/spa50x-30x-7-5-2b.bin
</Upgrade_Rule>
Sage Major
Brought up a syslog and found more info
curent firmware
7.4.9c
upgrade rule
http://xxxxxxxx/spa/firmware/50x/spa50x-30x-7-5-2b.bin
I get a message that I can't downgrade below 7.5.3 even though I am trying to upgrade to 7.5.2b from 7.4.9c
16:14:38          fu:1:0c30e, 6.8 7.13 1
16:14:38          fu:1:0c201, 4.71 1
16:14:38          [0]UnRegOK
16:14:38          request reboot type=1 reason=Provisioning(4)
16:14:38          fu:1:0c17e, 5.1.9 5.1.12 5.1.14 5.1.19 1
16:14:38          FMM >>>> Failed upgrade
16:14:38          SPA508G a4:4c:11:9e:27:91 -- Upgrade failed: 12. corrupt file
16:14:29          ** New magic: SkOsMo5 fIrMwArE. Old magic: SkOsMo5 fIrMwArE
16:14:29          fprv_upgrade_from_buffer_priv(manual:0, buf: SkOsMo5 fIrMwArE, file_len: 4194816)
16:14:29          content len (pld) =4194816
16:14:19          [0]RegOK. NextReg in 29 (1)
16:13:56          [0]RegOK. NextReg in 29 (1)
16:13:33          [0]RegOK. NextReg in 29 (1)
16:13:10          [0]RegOK. NextReg in 29 (1)
16:13:00          FMM >>>> Requesting upgrade
16:13:00          SPA508G a4:4c:11:9e:27:91 -- Requesting upgrade tftp://xxxxxxxxxx/spa/firmware/50x/spa50x-30x-7-5-4.bin
16:13:00          SPA508G a4:4c:11:9e:27:91 -- Requesting upgrade tftp://xxxxxxxxx/spa/firmware/50x/spa50x-30x-7-5-4.bin
fu:1:0bfc1, 5.1.9 1
SPA508G a4:4c:11:9e:27:91 -- Upgrade failed: downgrade to revision earlier than 7.5.3 not allowed
fprv_upgrade_from_buffer_priv(manual:0, buf: SkOsMo5 fIrMwArE, file_len: 4147359)
content len (pld) =4147359
content len (hdr) =4147359
SPA508G a4:4c:11:9e:27:91 -- Requesting upgrade http://xxxxxxxxxx/spa/firmware/50x/spa50x-30x-7-5-2b.bin
it seems your upgrade config is telling the device don't go below 7,5,3, but then install 7.5.2b??
I'd set this to 7.5.2b or make it empty...
7.5.3,>>
Downgrade_Rev_Limit Enforces a lower limit on the acceptable
version number during a firmware upgrade or
downgrade. The device does not complete a
firmware upgrade operation unless the
firmware version is greater than or equal to this
parameter.
To upgrade phone to 7.52b before other upgrade, you need a conditional, to only upgrade if the software version is less than 7.52b..
Syntax to tell if software version is  less than 7.5.2b then (the ? ) do the tftp....
($SWVER lt 7.5.2b) ? http://10.41.22.99/spa50x-30x-7-5-2b.bin
or to get to the latest, this should work to do both stages from 7.4.9
($SWVER lt 7.5.2b) ? http://10.41.22.99/spa50x-30x-7-5-2b.bin    |    ($SWVER lt 7.5.4) ? http://10.41.22.99/spa50x-30x-7-5-4.bin
Test in your lab to make sure it works before rolling out to your customers...
The full provisioning guide is here
http://www.cisco.com/en/US/docs/voice_ip_comm/csbpvga/spa100-200/provisioning/guide/SPA100-200_PG_78-20952.pdf
all the syntax, and config is there.
Dan.
